Api IRobotBarCableData
I created  Cables. I assigned  MaterialName ,  SectionAX.
1) I don't know how to assign data from cable to created bar
2) How to set AssemblingParameters to dataCable
IRobotBarCableAssemblingParamType.I_BCAPT_FORCE_FO
IRobotApplication robApp;
IRobotStructure structure;
 IRobotLabel Section;
string klasaStal = "S 355";
robApp = new RobotApplicationClass();
structure = robApp.Project.Structure;
 IRobotNodeServer inds = robApp.Project.Structure.Nodes;
IRobotBarServer ibars = robApp.Project.Structure.Bars;
                    IRobotBarCableData kabel;
                    string StrKabelSciana = "Kabel_2";
                    Section = structure.Labels.Create(IRobotLabelType.I_LT_BAR_CABLE, StrKabelSciana);
                    kabel = (IRobotBarCableData)Section.Data;
                    kabel.MaterialName = klasaStal;
                    kabel.SectionAX = 20 * 0.0001; // cm^2
                    RobotSelection iselKabelSciana = robApp.Project.Structure.Selections.Create(IRobotObjectType.I_OT_BAR);
              inds.Create(1, 0, 0, 0);
                inds.Create(2, 5, 5, 0);
                    ibars.Create(1, 1, 2); // kabel lewa strona
                    iselKabelSciana.AddOne(1);
                    ibars.SetLabel(iselSciagSciana, IRobotLabelType.I_LT_BAR_CABLE, StrKabelSciana);
                    ibars.SetLabel(iselSciagSciana, IRobotLabelType.I_LT_MATERIAL, klasaStal);
                    robApp.Project.Structure.Labels.Store(Section);
                    structure.Bars.SetLabel(iselSciagSciana, IRobotLabelType.I_LT_BAR_CABLE, StrSciagSciana);
                     IRobotBarCableAssemblingParamType kabelFo;
//kabelFo = IRobotBarCableAssemblingParamType.I_BCAPT_FORCE_FO;
                  //kabelFo.Equals
                  //  kabel.AssemblingParam = IRobotBarCableAssemblingParamType.I_BCAPT_FORCE_FO;
                  //  kabel.AssemblingParamValue = 100;
Thank You in Advance
I enclose the file, vs 2010, robot 2011
Rafal.Gaweda
Autodesk Support
Autodesk Support
Store label after creating \ modification.
        private void setgeometry()
            kabel.AssemblingParamValue = 1000;
            ibars.SetLabel(iselKabelSciana, IRobotLabelType.I_LT_BAR_CABLE, StrKabelSciana);
            ibars.SetLabel(iselKabelSciana, IRobotLabelType.I_LT_MATERIAL, klasaStal);
Rafal Gaweda
