I am looking to write a script that inputs steel reinforcement parameters.
This includes defining the yield strength of the bar, bar diameter and concrete cover
Is this possible through API?
I have seen this post here https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-bar-material-yield-strength-from-...
However I need to see some more code to be able to implement it myself as I am still relativity new to VBA.
Thanks in advance for the help,
Alex
Solved by Rafal.Gaweda. Go to Solution.
Hi @Anonymous
Some examples:
Private Sub CommandButton1_Click()
Dim robot As IRobotApplication
Dim monobjet As RobotObjObject
Dim Ferlabel As RobotLabel
Dim Ferlabledata As RConcr_BAEL_ReinforceData
Set robot = New RobotApplication
'ouverture
robot.Project.New I_PT_SHELL
'préference de l'affaire & Norme de calcul de ferraillage
Set ProjectPrefs = robot.Project.Preferences
ProjectPrefs.SetActiveCode I_CT_RC_THEORETICAL_REINF, "BAEL 91 mod. 99"
Set Ferlabel = robot.Project.Structure.Labels.Create(I_LT_PANEL_REINFORCEMENT, "BAEL2")
Set Ferlabledata = Ferlabel.Data
Ferlabledata.SetMainDirection I_CRD_ALONG_Z, 1, 1, 1 'Direction
Ferlabledata.Main.UnidirReinf = False 'Ferraillage dans une Direction
'=========parametre ELS
Ferlabledata.SLS_Deflection = True 'Etendue des calculs Fléche
Ferlabledata.SLS_DeflectionReinfCorrect = True 'Etendue des calculs Correction du ferrailage
Ferlabledata.CrackingBot = 3 'Fissuration - = autre
'Ferlabledata.CrackingBot = I_CBAELCT_OTHER 'Fissuration - = autre
Ferlabledata.CrackingTop = 3 'Fissuration + = autre
'Ferlabledata.CrackingTop = I_CBAELCT_OTHER 'Fissuration - = autre
'=========Ferraillage
Ferlabledata.BarDim_D1_Bot = 0.02
Ferlabledata.BarDim_D1_Up = 0.02
Ferlabledata.BarDim_D2_Up = 0.025
Ferlabledata.BarDim_D2_Bot = 0.032
robot.Project.Structure.Labels.Store Ferlabel
End Sub
Dim Robapp As New RobotApplication
Dim RC As RobotProjectComponent
Set RC = Robapp.Project.ComponentMngr.Create(I_PCT_BEAM, "B1", "1")
Dim IRCB As IRConcrBeam
Set IRCB = RC.Data
IRCB.Concrete.CharacteristicStrength = 20
IRCB.CalculationOptions.CoverBottom = 0.03
IRCB.Geometry.SpanNumber = 2
IRCB.LinearLoadsCount = 1
IRCB.LinearLoad(1).Case = 1
IRCB.LinearLoad(1).Nature = I_BLN_BEAM_NATURE_DEAD
IRCB.LinearLoad(1).Spans.Add 1
IRCB.LinearLoad(1).Spans.Add 2
IRCB.LinearLoad(1).Value1 = 1000
Dim IBS As IRConcrBeamSegment
Set IBS = IRCB.Geometry.Span(1).segment(1)
IBS.Dim(I_BSD_BEAM_SECTION_DIM_H1) = 1
IBS.Dim(I_BSD_BEAM_SECTION_DIM_B) = 0.5
Set IBS = IRCB.Geometry.Span(2).segment(1)
End Sub
Thanks @Rafal.Gaweda that is very helpful, exactly what I was looking for.
Do you know if it is possible to turn off the minimum reinforcement required (see attached) through API?
I have been looking through the forum as well as the API manual but still can't figure it out.
Thanks again for your help,
Alex
