(API) How create wooden beam with VBA
dscheven
dscheven
I have a question about VBA from excel to Robot structural.
How can I create an bar with an section 50x100 and timber material C18.
Below I post the code what I mean. Only the code is for concrete.
Thanks.
Public Sub CommandButton2_Click()
Dim Robot As New RobotApplication
Robot.Project.New I_PT_FRAME_2D
Robot.Project.Structure.Nodes.Create 1, Range("A2"), 0, 0
Robot.Project.Structure.Nodes.Create 2, Range("B2"), 0, 0
Robot.Project.Structure.Bars.Create 1, 1, 2
Dim Label As RobotLabel
Set Label = Robot.Project.Structure.Labels.Create(I_LT_SUPPORT, "Support")
Dim SupportData As RobotNodeSupportData
Set SupportData = Label.Data
SupportData.UX = 1
SupportData.UY = 1
SupportData.UZ = 1
SupportData.RX = 0
SupportData.RY = 0
SupportData.RZ = 0
Robot.Project.Structure.Labels.Store Label
Robot.Project.Structure.Nodes.Get(1).SetLabel I_LT_SUPPORT, "Support"
Robot.Project.Structure.Nodes.Get(2).SetLabel I_LT_SUPPORT, "Support"
Set Label = Robot.Project.Structure.Labels.Create(I_LT_BAR_SECTION, "Beam 50*50")
Dim section As RobotBarSectionData
Set section = Label.Data
section.ShapeType = I_BSST_CONCR_BEAM_RECT
Dim concrete As RobotBarSectionConcreteData
Set concrete = section.concrete
concrete.SetValue I_BSCDV_BEAM_B, 0.5
concrete.SetValue I_BSCDV_BEAM_H, 0.5
section.CalcNonstdGeometry
Robot.Project.Structure.Bars.Get(1).SetLabel I_LT_BAR_SECTION, "Beam 50*50"
Dim caseSW As RobotSimpleCase
Set caseSW = Robot.Project.Structure.Cases.CreateSimple(1, "SW", I_CN_PERMANENT, I_CAT_STATIC_LINEAR)
caseSW.Records.New I_LRT_DEAD
Dim LoadRec As RobotLoadRecord
Set LoadRec = caseSW.Records.Get(1)
LoadRec.SetValue I_DRV_Z, -1
LoadRec.SetValue I_DRV_ENTIRE_STRUCTURE, True
If Robot.Project.CalcEngine.Calculate = True Then
MsgBox Robot.Project.Structure.Results.Bars.Forces.Value(1, 1, 0.5).MY
End If
End Sub
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @dscheven
Here is example code :
Dim RLabel As RobotLabel
    Dim RLabelData As RobotBarSectionData
    Dim RLabelNSData As RobotBarSectionNonstdData
    Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_BAR_SECTION, "my_section")
    Set RLabelData = RLabel.Data
    RLabelData.Type = I_BST_NS_RECT
    RLabelData.ShapeType = I_BSST_RECT_FILLED
    Set RLabelNSData = RLabelData.CreateNonstd(0)
    RLabelNSData.SetValue I_BSNDV_RECT_B, 0.2
    RLabelNSData.SetValue I_BSNDV_RECT_H, 0.4
    RLabelData.MaterialName = "C18"
    RobApp.Project.Structure.Labels.Store RLabel
Rafal Gaweda
dscheven
Hi Rafal,
Thanks for the fast answer.
I tried to copy in it but when I run the code I get a error on this part
Set RLabel = robapp.Project.Structure.Labels.Create(I_LT_BAR_SECTION, "my_section12")
Am I doing something wrong?
Public robapp As RobotApplication
SupportData.UX = 1
SupportData.UY = 1
SupportData.UZ = 1
SupportData.RX = 0
SupportData.RY = 0
SupportData.RZ = 0
    robapp.Project.Structure.Labels.Store RLabel
End If
End Sub
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @dscheven
Replace "robapp" by "Robot"
Rafal Gaweda
dscheven
Thanks Rafal. It works.
