API: Get Data to Create Dimensioning Groups
StefanoPasquini6790
Advisor Advisor
Message 1 of 23
StefanoPasquini6790
Hi everyone,
I'm publishing my first "public" API.
This allow the user to import bars data from Robot and automaticly create dimensionig groups in Robot following seven different Criterion.
Starting by my wishlist post: http://forums.autodesk.com/t5/robot-structural-analysis/auto-grouping-rules-for-bar-checking/idi-p/5... , I've made it by myself.
You can download the API here: http://www.pasquiniprogetti.it/?p=868
The code is open, feel free to edit it.
I'm waiting for your feedback and suggestions to a better develop of the tool.
Have a good Robot, Cheers
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Replies (22)
Message 2 of 23
Romanich
Bravo Stefano!
One small tip: to increase speed use RobApp.Interactive = False at the start and RobApp.Interactive = True in the end of macro.
Another tip:
If Not RobApp.Visible Then
    Set RobApp = Nothing
    MsgBox "Open Robot and load Model", vbOKOnly, "ERROR"
    Exit Sub
End If
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 23
StefanoPasquini6790
Thanks a lot, I will try "MAESTRO!!!"
Cheers
PasProStudio
Message 4 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Great!
I will add to our list.
Small cosmetic changes for combos to have no empty records:
Private Sub ComboBox1_Enter()
'load the data from Excel List
Dim FirstLabel As String
'PASSAGGIO DALLA PRIMA ALLA SECONDA PAGINA
row = 2
While Range("ba" & row) <> ""
ComboBox1.AddItem Range("ba" & row)
row = row + 1
Wend
End Sub
Private Sub ComboBox2_Enter()
row = 2
While Range("bb" & row) <> ""
ComboBox2.AddItem Range("bb" & row)
row = row + 1
Wend
End Sub
Rafal Gaweda
Message 5 of 23
StefanoPasquini6790
Edited, Great....
PasProStudio
Message 6 of 23
StefanoPasquini6790
Hi everyone,
Added other five criterion.
greetings
PasProStudio
Message 7 of 23
StefanoPasquini6790
HI Artur,
installed robot 2016 and there is some issue....can you try to make some tests?
It can depend by the registration????
Thanks a lot
PasProStudio
Message 8 of 23
Romanich
Hi Stefano,
Picture size is really small.
Could you add the button "Remove Groups from Robot"?
Message 9 of 23
StefanoPasquini6790
Hi Roman,
Very nice suggestion, I will work on it when I will solve the problems with ARSA2016 compatibility.
Thank you
PasProStudio
Message 10 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
Stefano,
It is related to not fully \ correctly registered API interfaces
Run as Admin "C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2016\System\Exe\rsetup.exe" /ReRegServer
or similar concerning your versions :
http://forums.autodesk.com/t5/robot-structural-analysis/vba-excel-macro-for-any-object-geometry-modi...
but it must be done with ADMINISTRATOR RIGHTS
Rafal Gaweda
Message 11 of 23
StefanoPasquini6790
Hi API experts,
I made a large use of this tool, it give me the power to manage easily big models and create dimensioning groups to optimize my steel structures.
Anyway, I'd like to improve it, but I don't have the right knowledge to do it therefore, if someone can suggest me how, I will appreciate too much. This are the topics that I want to improve:
1) the creation of the lists that contain the cross section and the bar type present in the model are very time consuming. Now I've improved the tool that create the lists only one time, and until nothing change in the model...there is some way to do it faster (read from robot the lists, a different way to create lists....or any other workaround????)
2) It will be very useful to manage also the deleting of groups, as suggested by Romanich, but I can't do it.....Smiley Embarassed
I'm sorry for my basic questions but I'm not a programmer....I only try to be!!!
PasProStudio
Message 12 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
    Dim RDMServer As RDimServer
    Dim RDMGrps As RDimGroups
    Set RDMServer = RobApp.Kernel.GetExtension("RDimServer")
    RDMServer.Mode = I_DSM_STEEL
    Set RDMGrps = RDMServer.GroupsService
    RDMGrps.Delete group_number
Rafal Gaweda
Message 13 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
    Dim RSelection As RobotSelection
    Set RSelection = RobApp.Project.Structure.Selections.CreateByLabel(I_OT_BAR, I_LT_BAR_SECTION, sec_name)
    Set RSelection = RobApp.Project.Structure.Selections.CreateByLabel(I_OT_BAR, I_LT_MEMBER_TYPE, membertype_name)
Rafal Gaweda
Message 14 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
HINT:
RobApp.Project.Structure.Labels.GetMany(...)
will return labels used on model
Rafal Gaweda
Message 15 of 23
StefanoPasquini6790
WOW....
I will try to improve my tool....and then I will share it!!!
Thanks a lot Mister Rafal...
PasProStudio
Message 16 of 23
StefanoPasquini6790
Good morning at all,
Just released the fourth version, incredibly improved, of the DIM Groups Manager.
You can find it here:
Enjoy it
PasProStudio
Message 17 of 23
Hi Stefano,
First of all, thank you very much for all your hard work you put into this pluging, it is working perfect.
However, I've got one issue with, that is not being able to define the range of sections out of which Robot would pick up the most efficient one during the design process. Am I missing something or it really is not currently possible? To make it clear I attached a PDF showing the window in which we normally define these section ranges. So is the functionality of this window available in your plugin? Do you know how it can be done?
Thank you,
Michal
Message 18 of 23
StefanoPasquini6790
Hi Michal,
unfortunately I can't manage this tool inside the API but, when you create a DIM group in robot, he automatically assign the cross section family that the elements already have...for example, if you create a DIM group for elements that have assigned the cross section HEA, also different kind of HEA in group, Robot use HEA to optimize the group members. This could be a good shortcut to manage the dimensioning phases....when you want to investigate deeply your optimization, you have to assign manually the cross sections that you want to use, as you shown in your pdf.
Hope I help you, cheers.
PasProStudio
Message 19 of 23
Rafal.Gaweda
Autodesk Support
Autodesk Support
If I follow your discussion correctly : take a look at "Robot API SteelDesign.pdf" , chapter 4.4.3 -> pages 96, 97
Rafal Gaweda
Message 20 of 23
Stefano, thanks for your quick reply, this helps a lot.
To be honest I was not quite aware that Robot would look at the range of sections according to the type of section already assigned to a member. I always defined the range I wanted to in the code group definition 🙂 We learn all the time, don't we?
I still wonder, though, whether or not in the future it would be possible to define this range independently from the type of section already assigned 🙂 For example I would like Robot to look at the tubular and I sections at the same type for a given group. And then I would choose the one I like the most. I know that in real life we usually know what type of section the member going to have, however I meant more conceptual projects where before the design it's sometimes hard to say what type of section would work most efficiently (axial forces + biaxial bending + torsion + high shear). Anyway, thanks again and I hope to see your tool developing further 🙂
Have a good day,
M.
