(API) FINITE ELEMENT SELECTION BY FLOOR
is there a way of selecting finite elements on a floor?
I've tried the following but it selects something else.
IRobotStoreyMngr currentStorey = robApp.Project.Structure.Storeys.Get(1).Name;
RobotSelection felemSelection = robApp.Project.Structure.Selections.CreateByStorey(IRobotObjectType.I_OT_FINITE_ELEMENT, currentStorey);
Rafal.Gaweda
Autodesk Support
Autodesk Support
it seems this works correctly:
RobApp.Project.Structure.Selections.CreateByStorey(I_OT_PANEL, "Story 1")
so from panel select FEs
Rafal Gaweda
But in this way it is not possible to get Finite element's particular object data (i.e nodes)
Because the selection is panel objects.
IRobotCollection panelCollection = robApp.Project.Structure.Objects.GetMany(panelSelection);
var PL = panelCollection.get(1); -> returns a panel object
string felems = PL.FiniteElems; -> returns a string of Finite elements
It would be nice to use like below to get the nodes.
RobotSelection felemSelection = robApp.Project.Structure.Selections.CreateByStorey(IRobotObjectType.I_OT_FINITE_ELEMENT, "Story 1");
IRobotCollection felemCollection = (IRobotCollection)robApp.Project.Structure.FiniteElems.GetMany(felemSelection);
RobotFiniteElement FE = felemCollection.get(1);
RobotFiniteElementNodes nodes = FE.Nodes;
int nodeCount = nodes.Count;
nodes.Get(1);
nodes.Get(2);
nodes.Get(3);
However it seems that its not possible now...?
Rafal.Gaweda
Autodesk Support
Autodesk Support
robApp.Project.Structure.Selections.CreateByStorey(IRobotObjectType.I_OT_NODE, "Story 1")
This should be the easiets way, but unfortunately it does not work (like FE selection) by story
Rafal Gaweda
Rafal.Gaweda
Autodesk Support
Autodesk Support
Getting FE nodes
Dim FEData As RobotFiniteElementData
Dim x As Double, y As Double, z As Double ' nodal coordinates to return
For i = 1 To 24 Set FEData = RobApp.Project.Structure.FiniteElems.Get(i) For j = 1 To FEData.NodeCount NodeNumber = FEData.GetNode(j, x, y, z) Next j Next i
Rafal Gaweda
