API extract quantity survey
AbelSV78
AbelSV78
Dear Sirs,
I need to stract data of Quantity Survey of all the structure from Robot. I need something similar to attached image. I have found out "Irobotstructurequantity" variable, but I do not know how to use it. Could you give me the code to extract it into excel from VB.net??
Thank you in advance, regards
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example for Material and Bars survey:
Dim RobApp As New RobotApplication
Dim Mat As RobotMaterialQuantitySurvey
Dim MatLabel As RobotLabel
Dim MatData As RobotMaterialData
Row = 7
Set Mat = RobApp.Project.Structure.QuantitySurvey.Materials
For i = 1 To Mat.Count
    Cells(Row, 1) = Mat.GetName(i)
    Set MatLabel = RobApp.Project.Structure.Labels.Get(I_LT_MATERIAL, Mat.GetName(i))
    Set MatData = MatLabel.Data
    Cells(Row, 2) = MatData.E
    Cells(Row, 3) = MatData.Kirchoff
    Cells(Row, 4) = MatData.RO
    Cells(Row, 5) = MatData.NU
    Cells(Row, 6) = Mat.GetVolume(I_OT_BAR, i)
    Cells(Row, 7) = Mat.GetWeight(I_OT_BAR, i)
    Row = Row + 1
Next i
Row = Row + 1
Dim BQ As RobotBarSectionQuantitySurvey
Set BQ = RobApp.Project.Structure.QuantitySurvey.BarSections
For i = 1 To BQ.Count
    Cells(Row + i, 1) = BQ.GetName(i)
    Cells(Row + i, 2) = BQ.GetLength(i)
    Cells(Row + i, 3) = BQ.GetWeight(i)
    Cells(Row + i, 4) = BQ.GetVolume(i)
    Row = Row + 1
Next i
or create table I_TT_MEASURE and save it as txt (=csv)
Rafal Gaweda
AbelSV78
OK, it works..
thank you.
"or create table I_TT_MEASURE and save it as txt (=csv)" : could you give me a code example please...
It's possible do a code to get the quantity survey only a selected bar or a group of bars?
Thank you.
Best regards,
Rafal.Gaweda
Autodesk Support
Autodesk Support
By dumping filtered quantities table
Example:
Private Sub CommandButton1_Click()
Dim RobApp As RobotApplication
Set RobApp = New RobotApplication
Dim t As RobotTable
Dim tf As RobotTableFrame
Dim path As String
Dim Fullpath As String
Dim FName As String
path = Environ$("temp")
Dim nTables As Long
Set t = RobApp.Project.ViewMngr.CreateTable(I_TT_MEASURE, I_TDT_DEFAULT)
t.Select I_ST_BAR, "1 3to6" Set tf = RobApp.Project.ViewMngr.GetTable(1) FName = tf.Window.Caption spacepos = InStr(1, FName, " ") If spacepos <> 0 Then FName = Left(FName, spacepos - 1) + "_" End If tf.Get(1).Window.Activate Set t = tf.Get(1) tf.Current = 1 tabname = tf.GetName(1) tabname = Replace(tabname, " ", "_") DoEvents Fullpath = path + "\" + FName + tabname + ".txt" t.Printable.SaveToFile Fullpath, I_OFF_TEXT ansifilepath = Left(Fullpath, Len(Fullpath) - 4) + "_ansi.txt" X = Shell("cmd.exe /A /C TYPE " + Fullpath + " > " + ansifilepath, vbNormalFocus) DoEvents For Iii = 1 To 10000000 aaa = Iii Next Iii Workbooks.OpenText Filename:=ansifilepath, DataType:=xlDelimited, Semicolon:=True MsgBox "Dumping finished" Set RobApp = Nothing End Sub
Rafal Gaweda
