API - Estimation of reinforcement weight for all RC Beams and RC Columns
Artur.Kosakowski
Autodesk Support Autodesk Support
Message 1 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi all,
In case you need to determine the estimated weight of reinforcement of RC beams and Rc Columns from your model and you calculated their required reinforcement you can easily do this by pressing a button in the macro created by @marcinrakus (thank you Marcin).
This is how it works:
Artur Kosakowski
Replies (10)
Message 2 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
The macro itself is attached to this post.
Artur Kosakowski
Message 3 of 11
Refaat
Dear Artur
Thank you so much. It is really useful marco (good idea).
But I would like to ask you if possible to develop this macro to be more practical. On the other hand to provide us the quantity of each reinforcement diameter separately and the final results present in the tabular format.
Keep up the good work!
Refaat
Message 4 of 11
Jummybear
Nice API, Indeed. Slab need to be added 🙂
Message 5 of 11
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Refaat
Unfortunately there is no access to bar diameters used for given beam or column via COM so this cannot be done until this information is available in RSA API Smiley Sad
I'm sure somebody with Excel skills will be able to edit the macro and give it a better look Smiley Happy
Artur Kosakowski
Message 6 of 11
shulwh
Nice macro that makes it easier to estimate the cost of a building!
By the way, is it possible to calculate the reinforcement weight of the shear wall through API🤔?
Message 7 of 11
2022pcs5311
Hi @Artur.Kosakowski
I'm trying to understand the macro on Reinforcement weight calculation but not able to get from where you have provided "resIdForLongitudinal = 1142", "resIdForTransverse = 1947". Could you please suggest me any reference from I can get this? I have tried from API also but didn't find anything related to this.
Message 8 of 11
Stephane.kapetanovic
hi @2022pcs5311
Sometimes, column indexes are provided on the forum; other times, you may need to search for them yourself or create a bot.
It's best to ask here if you can't find them.
Best Regards
737Reinforcement type
921Minimum reinforcement ratio (%)
922Required reinforcement ratio (%)
923Maximum reinforcement ratio (%)
1142Provided reinforcement ratio (%)
1143Max. reinforcement area (cm2)
1144Min. reinforcement area (cm2)
1156Reinforcement parameters
1169Max. code-defined reinforcement ratio (%)
1170Min. code-defined reinforcement ratio (%)
1171Average reinforcement ratio (%)
1173Top required reinforcement (My) (cm2)
1174Bottom required reinforcement (My) (cm2)
1175Top provided reinforcement (My) (cm2)
1176Bottom provided reinforcement (My) (cm2)
1177Required reinforcement along b (cm2)
1178Required reinforcement along h (cm2)
1179Provided reinforcement along b (cm2)
1180Provided reinforcement along h (cm2)
1181Top reinforcement - distribution (My)
1182Bottom reinforcement - distribution (My)
1183Reinforcement along b - distribution
1184Reinforcement along h - distribution
1185Transversal reinforcement - type/distribution
1202Top required reinforcement (Mz) (cm2)
1203Bottom required reinforcement (Mz) (cm2)
1204Top provided reinforcement (Mz) (cm2)
1205Bottom provided reinforcement (Mz) (cm2)
1206Top reinforcement - distribution (Mz)
1207Bottom reinforcement - distribution (Mz)
1947Transverse reinforcement density (cm2/m)
6733Transversal reinforcement - type/distribution NN
8106Reinforcement type NN
9201Reinforcement Areas NN
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 9 of 11
2022pcs5311
Dear @Stephane.kapetanovic
Thank you so much. In addition to this i need reinforcement and concrete weight separately for walls and slabs By using excel VBA. Could you please suggest me any macro file or reference for this ? This will be really grateful.
Message 10 of 11
The provided code is for bars, specifically beams and columns. it's a topic worth considering for future development.
Message 11 of 11
2022pcs5311
Okay, Thanks a lot.
