API - Difference between methods
cool.stuff
cool.stuff
Hi!
I've been reading about API methods to get bar forces and I have not been able to find the explanation anywhere.
What is the difference, in practice, between bar forces and BarForceServer.ValueEx and BarForceServer.Value?
Many thanks in advance
Stephane.kapetanovic
hi @cool.stuff
'ValueEx' is used to extract forces in case of code combinations or moving loads and 'Value' in case of simple cases or manual combinations
Dim BFD as IRobotBarForceData
Dim bar_num As long, case_num As long, case_cmpnt As long, point As double
Set BarForceServer = RobApp.Project.Structure.Results.Bars.Forces
With BarForceServer
  set BFD  = .ValueEx(bar_num, case_num, case_cmpnt, point) ' Code combination
  set BFD  = .Value(Value(bar_num, case_num, point) ' Others
End with
see getting internal forces from RSA to XL (API) and 866-867 of Robot Object Model pdf file.
Best Regards
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
cool.stuff
Many thanks for the clear explanation 🙂
Best regards
