I was wondering what is the difference between the properties assigned to the bar (BarServer) and the concrete column/beam created through the Component Manager. For instance, in the case of the bar, the rectangular section for columns has label 'I_BSCDV_COL_B' (or H), while the component column has label 'I_CCT_COLUMN'.
I think that in the case of the component it is also possible to specify the type of reinforcement, as in this example
https://forums.autodesk.com/t5/robot-structural-analysis-forum/api-define-column-reinforcements-in-r...
I also assume that in the case of the component, you go straight to the RC member interface, while in the other case you work mainly in the geometry interface.
However, is there any chance to get to the window as in the email attached through the API?
Thank you in advance
