[API] Define Membertype Adjoin Params
BadrDerouiche
BadrDerouiche
Trying to define automation for member type with Adjoin member.
I founded documentation in the Robot Steel API, can assign deferent parameter but I couldn't access to "IRDimAdjoinParams" interface which is the key according to the documentation.
Any help or insight will be appreciated,
Best Regards,
Badr
Stephane.kapetanovic
hi @BadrDerouiche
try this
IRobotApplication RobApp = new RobotApplication();
RobotLabelServer Labels = RobApp.Project.Structure.Labels;
RobotProjectPreferences Preferences = RobApp.Project.Preferences;
int Code = Preferences.SetActiveCode(IRobotCodeType.I_CT_STEEL_STRUCTURES,
                                       "NF EN 1993-1-1:2005/NA:2013/A1:2014");
RDimServer DimServer = RobApp.Project.DimServer;
           DimServer.Mode = IRDimServerMode.I_DSM_STEEL;
RDimConnection Connection = DimServer.Connection;
RDimAdjoinParams AdjParams = Connection.GetAdjoinParams();
void SetAdjMemb(IRDimAdjoinMembSuppCond AdjBeamSuppCond,
                params int[] Numbers) {
   IRDimAdjoinMembNo No; bool isBeam;
   for (int i = 0; i < Numbers.Length; i++) {
      No = (IRDimAdjoinMembNo)(i + 1); isBeam = (i + 1) % 3 != 0;
      AdjParams.SetMemberUserNo(No, Numbers[i]);
      if (isBeam) AdjParams.SetMemberSuppCond(No, AdjBeamSuppCond);
string LabelName = "Column_7";
IRobotLabel Lbl = Labels.Create(I_LT_MEMBER_TYPE, LabelName);
IRDimMembDefData LblData = Lbl.Data;
IRDimMembParamsE32 MParams = (IRDimMembParamsE32)LblData.CodeParams;
MParams.BucklingDiagramY = I_DBD_E32_INTERN_ADJBAR_6;
SetAdjMemb(I_DAMSC_SUPPCOND_MIXED, 1, 2, 3, 4, 5, 6);
LblData.SetStructureSwayYZ(I_DMDBDT_BUCKLING_Y, 1);
LblData.RetrieveAdjoinParamsYZ(I_DMDBDT_BUCKLING_Y, AdjParams);
LblData.CodeParams = MParams;
Labels.Store(Lbl);
int BarNo = 7;
RobApp.Project.Structure.Bars.Get(BarNo).SetLabel(I_LT_MEMBER_TYPE, LabelName);
Best Regards
Other cases are possible, for example
MParams.BucklingDiagramY = I_DBD_E32_PINNED_ADJBAR_3;
SetAdjMemb(I_DAMSC_SUPPCOND_MIXED, 1, 2, 3);
see also : Member type adjoining members via API using VBA
Stéphane Kapetanovic
don't forget to click the Accept Solution button and leave a < like !
BadrDerouiche
Hi @Stephane.kapetanovic ,
Sorry being late, that's work perfectly.
Thanks a lot for your help.
Best regard,
