API - CREATE DIMENSIONING GROUPS
StefanoPasquini6790
Advisor Advisor
Message 1 of 11
StefanoPasquini6790
Good morning at all,
I'm writing a Macro to generate steel dimensioning bar groups via API in excel VBA (I'm not really expert programmer), I can't find the right way to my program code.
Can someone correct my code?
One more issues, I have to extract from the opened Robot model this data for bars:
1) Section Label;
2) Bar Type;
3) ULS Design Ratio.
Attached you can find the source code and the reference excel file.
Sorry for my basic questions....Smiley Embarassed
Thanks in advance, greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Replies (10)
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example attached
Rafal Gaweda
Message 3 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Mind that to get steel design ratio you have to run steel design by macro \ API
Example attached.
Rafal Gaweda
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example
Dim Bar As RobotBar
Dim Sec As RobotBarSection
Dim MTLabel As RobotLabel
Dim BarCol As RobotBarCollection
Set BarCol = RobApp.Project.Structure.Bars.GetAll
For i = 1 To BarCol.Count
    Set Bar = BarCol.Get(i)
    Set Sec = Bar.GetLabel(I_LT_BAR_SECTION)
    Set MTLabel = Bar.GetLabel(I_LT_MEMBER_TYPE)
    Cells((7 + i), 1) = Bar.Number
    Cells((7 + i), 2) = Sec.Name
    Cells((7 + i), 3) = MTLabel.Name
Next i
Rafal Gaweda
Message 5 of 11
StefanoPasquini6790
Sorry,
one more question.
If I have in the model some bars with no dimesioning rule assigned, the MACRO debug:
How can I tell to the macro to "jump" to the next element? With a simple cicle (the green one) I have no results....
PasProStudio
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
If Not Bar.HasLabel(I_LT_MEMBER_TYPE) Then GoTo 10
Rafal Gaweda
Message 7 of 11
StefanoPasquini6790
Good MOrning.
One more issue, if I have in the model some bars that in dimensioning phase have some warning (for example thin walled sections, or any other kind of warnings...) the macro of Dim Ratio debug.
How can avoid this issue?
Greetings
PasProStudio
Message 8 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Do you want to report them ? They do not block design calculations.
Rafal Gaweda
Message 9 of 11
StefanoPasquini6790
HI Rafal,
No, I don't want to report them, but the calculation of ratio debug when the first warning it appear.
This is the code:
Sub GetRatioFromRobot()
Dim UlsLoadCase As Integer
Dim RobApp As IRobotApplication
Set RobApp = New RobotApplication
'Get the collection of all bars from the structure.
'Declare and create the object giving access to standard section parameters.
Set bar_col = RobApp.Project.Structure.Bars.GetAll()
UlsLoadCase = InputBox("INSERISCI IL NUMERO DI COMBINAZIONE SLU IN ROBOT")
'Iterate for consecutive bars from the collection.
For I = 1 To bar_col.Count
'Dim RobApp As RobotApplication
'Set RobApp = New RobotApplication
Dim RDMServer As IRDimServer
Set RDMServer = RobApp.Kernel.GetExtension("RDimServer")
RDMServer.Mode = I_DSM_STEEL
Dim RDmEngine As IRDimCalcEngine
Set RDmEngine = RDMServer.CalculEngine
'the part below is optional if you want to set caclulation parameters by the code
Dim RDmCalPar As IRDimCalcParam
Dim RDmCalCnf As IRDimCalcConf
Set RDmCalPar = RDmEngine.GetCalcParam
Set RDmCalCnf = RDmEngine.GetCalcConf
Dim RdmStream As IRDimStream 'Data stream for setting parameters
Set RdmStream = RDMServer.Connection.GetStream
RdmStream.Clear
'Calculate results for all sections
RdmStream.WriteText ("all") ' member(s) selection
RDmCalPar.SetObjsList I_DCPVT_MEMBERS_VERIF, RdmStream 'members verification
RDmCalPar.SetLimitState I_DCPLST_ULTIMATE, 1
RdmStream.Clear
RdmStream.WriteText (UlsLoadCase) 'Set Load Case(s)
RDmCalPar.SetLoadsList RdmStream
RDmEngine.SetCalcConf RDmCalCnf
RDmEngine.SetCalcParam RDmCalPar
'end of calclulation parameter settings
RDmEngine.Solve Nothing
Dim RDmDetRes As IRDimDetailedRes
Dim RDMAllRes As IRDimAllRes
Set RDMAllRes = RDmEngine.Results
Set RDmDetRes = RDMAllRes.Get(I)
Range("e" & I + 1) = RDmDetRes.Ratio
Next
End Sub
and attache you can find the file that give the warnings
PasProStudio
Message 10 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Corrected code
Row = 1
If bar_col.Get(I).HasLabel(I_LT_MEMBER_TYPE) Then
RdmStream.Clear
RdmStream.WriteLong (bar_col.Get(I).Number) ' member(s) selection
RdmStream.Clear
RdmStream.WriteText Str(UlsLoadCase) 'Set Load Case(s)
Set RDmDetRes = RDMAllRes.Get(bar_col.Get(I).Number)
'Range("d" & Row) = Str(bar_col.Get(I).Number)
Range("e" & Row) = RDmDetRes.Ratio
Row = Row + 1
End If
Next
Rafal Gaweda
Message 11 of 11
StefanoPasquini6790
Hi everybody;
published the version n°3 of the tool, edited and optimized.
Hope you enjoy, cheers.
http://www.pasquiniprogetti.it/?p=868
PasProStudio
