(API) Correct Modal analysis?
jokiller70
Message 1 of 29
jokiller70
Am I doing this right? I get the same Frequency even if I add loads?
Replies (28)
Message 21 of 29
jokiller70
Could it be I am using 64 bit code?
This is what happens when I issue your code;
Dim robapp As RobotApplication
        robapp = New RobotApplication
        Dim cas As RobotSimpleCase
        Dim rec As RobotLoadRecord
        Dim ModalParams As RobotModalAnalysisParams
        Dim ModalCase As RobotSimpleCase
        Dim I_CN_EXPLOATATION As Integer = 1
        Dim I_MARV_FACTOR As Integer = 3
        Dim I_MARV_CASE_NUM As Integer = 4
        Dim I_MARV_ACTIVATION_DIR As Integer = 6
        Dim I_MARV_SIGN As Integer = 7
        Dim I_MARV_INPUT_DIR_Z As Integer = 2
        Dim I_CAT_DYNAMIC_MODAL As Integer = 11
        Dim I_MARV_INPUT_DIR_X As Integer = 0
        Dim I_MARV_INPUT_DIR_Y As Integer = 1
        Dim I_LRT_MASS_ACTIVATION As Integer = 39
        ModalCase = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, "Modal", I_CN_EXPLOATATION _
        , IRobotCaseAnalizeType.I_CAT_DYNAMIC_MODAL)
        ModalParams = ModalCase.GetAnalysisParams
        ModalParams.DisregardDensity = True
        ModalCase.SetAnalysisParams(ModalParams)
        cas = robapp.Project.Structure.Cases.Get(-1)
        rec = cas.Records.Create(I_LRT_MASS_ACTIVATION)
        rec.SetValue(I_MARV_FACTOR, 1.2)
        rec.SetValue(I_MARV_CASE_NUM, 2)
        rec.SetValue(I_MARV_ACTIVATION_DIR, 2)
        rec.SetValue(I_MARV_SIGN, -1)
        rec.SetValue(I_MARV_INPUT_DIR_X, 1)
        rec.SetValue(I_MARV_INPUT_DIR_Y, 1)
        rec.SetValue(I_MARV_INPUT_DIR_Z, 1)
        robapp.Project.CalcEngine.GenerateModel()
 video here;
https://screencast.autodesk.com/Main/Details/c3a3df37-81ba-4931-9b71-6e92c12b51e2
Message 22 of 29
jokiller70
Soved it with 32bit code! Robot API also works a lot faster! Autocad nearly same performance. Now to the big question, what is the correct value for self resonant frequency?
Message 23 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
you can not convert in some of your models (at least the ones you sent us) case 2
because there no loads in it.
So compile your code using "Any CPU" settings
Rafal Gaweda
Message 24 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
All of them are listed in the table you attached to your post.
Rafal Gaweda
Message 25 of 29
jokiller70
And the Natural frequency?
Message 26 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
First column : Frequency (Hz) results
Rafal Gaweda
Message 27 of 29
jokiller70
from this ;
http://forums.autodesk.com/t5/robot-structural-analysis/eigen-values-natural-frequencies/td-p/351684...
post;
"Just be careful with how you understand modal analysis. The term "natural" frequency is not applied to every mode. Every mode has a frequency associated with it. That may not be the "natural" one for the structure. If you only get three modes this could be OK for a simple structure, depends on a lot of things. "
Message 28 of 29
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not know he meant. Ask Tony Ridley.
Robot calculates natural frequencies  in Modal analysis.
http://help.autodesk.com/view/RSAPRO/2015/ENU/?guid=GUID-3400C9A4-F47F-4A7F-9B67-66BEE7B9105A
Rafal Gaweda
Message 29 of 29
jokiller70
Found the problem! I had robapp.UserControl set to False
