Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
(API) Command VBA Projection Capture of a view
146 REPLIES 146
Message 1 of 147
11728 Views, 146 Replies
I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
146 REPLIES 146
Message 121 of 147
Artur.Kosakowski
Is there a way to access the results map scale normalize button using API?
No, there is not.
Artur Kosakowski
Message 122 of 147
in reply to: Artur.Kosakowski
Ok thanks.
I'm also trying to output a panel local axis direction vector using "GetDirX" function. It seems the function will only output 0, 0, 0? Can you tell me what I'm doing wrong?
                    Dim xVec As Double, yVec As Double, zVec As Double
                    With FEparams
                        .Panel = PanelCol.Get(ii).Number
                        .GetDirX xVec, yVec, zVec
                    End With
Thanks.
Message 123 of 147
Rafal.Gaweda
  Dim RSel As RobotSelection
    Set RSel = RobApp.Project.Structure.Selections.CreateFull(I_OT_PANEL)
    Dim PanelCol As RobotObjObjectCollection
    Set PanelCol = RobApp.Project.Structure.Objects.GetMany(RSel)
    Dim X As RobotGeoPoint3D, Y As RobotGeoPoint3D, Z As RobotGeoPoint3D
    Dim Obj As RobotObjObject
    Set X = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
    Set Y = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
    Set Z = RobApp.CmpntFactory.Create(I_CT_GEO_POINT_3D)
    For ii = 1 To PanelCol.Count
        Set Obj = PanelCol.Get(ii)
        Obj.Main.Attribs.GetLCS X, Y, Z
        Cells(12 + ii, 3) = Obj.Number
        Cells(12 + ii, 4) = "LCS X=" + Str(X.X) + ";" + Str(X.Y) + ";" + Str(X.Z)
        Cells(12 + ii, 5) = "LCS Y=" + Str(Y.X) + ";" + Str(Y.Y) + ";" + Str(Y.Z)
        Cells(12 + ii, 6) = "LCS Z=" + Str(Z.X) + ";" + Str(Z.Y) + ";" + Str(Z.Z)
    Next ii
Rafal Gaweda
Message 124 of 147
in reply to: Rafal.Gaweda
.GetLCS isn't available or mentioned anywhere in the API user guide. I'm using Robot 2014 Professional. Is there any other method for this version?
Thanks.
Message 125 of 147
Rafal.Gaweda
In this version you can get only local X
    Dim X As Double, Y As Double, Z As Double
    Obj.Main.Attribs.GetDirX X, Y, Z
Rafal Gaweda
Message 126 of 147
@Rafal.Gaweda could you have a look to the code that you wrote some years ago...seems doesn't work.
There are a lot of posts and I'm getting confuse. Is it possible to have just the code for having a screenshot from Robot please?
Message 127 of 147
Rafal.Gaweda
Hi @Anonymous
Example code
Sub screen_capture()
Dim viewRobot As IRobotView3
Set viewRobot = robapp.Project.ViewMngr.GetView(1)
Dim ScPar As RobotViewScreenCaptureParams
Set ScPar = robapp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
ScPar.Name = "capture"
ScPar.UpdateType = I_SCUT_CURRENT_VIEW
ScPar.Resolution = I_VSCR_4096
viewRobot.MakeScreenCapture ScPar
robapp.Project.PrintEngine.AddScToReport "capture"
End Sub
Rafal Gaweda
Message 128 of 147
@Rafal.Gaweda Where I should get the screen?
Message 129 of 147
Rafal.Gaweda
Hi @Anonymous
As always, in Printout Composition
Rafal Gaweda
Message 130 of 147
@Rafal.Gaweda Why do I get several screen (around 12), I would like to get just one!
Message 131 of 147
Rafal.Gaweda
Hi @Anonymous
Delete all screen captures from the file, try your code, if needed debug your code.
Rafal Gaweda
Message 132 of 147
@Rafal.Gaweda I still get several picture.
I'm trying to get a screen in a path like that:
RobApp.Project.PrintEngine.ScreenCaptures "c:\test1.jpeg", I_OFF_RTF_JPEG
or
RobApp.Project.PrintEngine.SaveReportToFile  "c:\test2.jpeg", I_OFF_RTF_JPEG
Both lines don't work!
Message 133 of 147
Rafal.Gaweda
HI @Anonymous
Files extensions should be rtf
fichier_sortie = "d:\prb\outjpg.rtf"
RobApp.Project.PrintEngine.SaveReportToFile fichier_sortie, I_OFF_RTF_JPEG
fichier_sortie = "d:\prb\out.rtf"
Rafal Gaweda
Message 134 of 147
@Rafal.Gaweda Is it no possible to get a picture file instead of rtf?
Message 135 of 147
Rafal.Gaweda
Hi @Anonymous
No
Rafal Gaweda
Message 136 of 147
@Rafal.Gaweda what about excel? Is it possible to get a screen from Robot in the excel file?
Message 137 of 147
Rafal.Gaweda
Hi @Anonymous
You may try (I personally have never checked it) to make screen capture to clipboard and then paste it in Excel
ScPar.UpdateType = I_SCUT_COPY_TO_CLIPBOARD
view.MakeScreenCapture ScPar
Rafal Gaweda
Message 138 of 147
Hi @Rafal.Gaweda,
I want screen captures for MXX,MYY and so on (sectional forces and moments) for the structure that I have. I want to just save these screen captures in jpeg format in a folder so that I can use them later.
I have written the following code:
IRobotView3 mavuerobot = Robapp.Project.ViewMngr.GetView(1) as IRobotView3;
mavuerobot.Selection.Get(IRobotObjectType.I_OT_CASE).FromText("1");
mavuerobot.Redraw(1);
mavuerobot.Projection = IRobotViewProjection.I_VP_3DXYZ;
mavuerobot.ParamsFeMap.CurrentResult = IRobotViewFeMapResultType.I_VFMRT_DETAILED_MOMENT_XX;
mavuerobot.Visible = 1;
Robapp.Project.ViewMngr.Refresh();
RobotViewScreenCaptureParams ScPar = Robapp.CmpntFactory.Create(IRobotComponentType.I_CT_VIEW_SCREEN_CAPTURE_PARAMS);
ScPar.Name = "First capture";
ScPar.UpdateType =IRobotViewScreenCaptureUpdateType.I_SCUT_CURRENT_VIEW;
ScPar.Resolution =IRobotViewScreenCaptureResolution.I_VSCR_4096;
mavuerobot.MakeScreenCapture(ScPar);
Could you please help me as to how I should save the screen capture in .jpeg now? And I am correctly capturing the screen capture for panel MXX through the above code?
Message 139 of 147
Rafal.Gaweda
Hi @Anonymous
I hope my answer in post 135 is clear enough.
Rafal Gaweda
Message 140 of 147
Hi @Rafal.Gaweda,
Thank you for your response
How do I take the screen capture and put it in an Excel file?
