(API) Command VBA Projection Capture of a view
Message 1 of 147
I have a problem with my macro. The command of projection in 3D doesn't work. My view stay in XZ plane.
robapp.Window.Activate
Set mavueRobot = robapp.Project.ViewMngr.CreateView(1)
mavueRobot.Projection = I_VP_3DXYZ
mavueRobot.Visible = True
mavueRobot.Redraw (True)
I want also make a capture of my model with diagram of results. Have you an example of code for it ?
I would like to get for final result the exemple in attachment.
Replies (146)
Message 141 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
See post 137.
Rafal Gaweda
Message 142 of 147
Hi @Rafal.Gaweda,
I did the same. I copied the screen capture on to the clipboard and tried to paste it in Excel. It doesn't work. The screen capture is in what format? I am unable to get that.
if (Clipboard.GetDataObject() != null)
IDataObject data = Clipboard.GetDataObject();
if (data.GetDataPresent(DataFormats.Bitmap))
Image image = (Image)data.GetData(DataFormats.Bitmap, true);
image.Save("image.bmp", System.Drawing.Imaging.ImageFormat.Bmp);
image.Save("image.jpg", System.Drawing.Imaging.ImageFormat.Jpeg);
image.Save("image.gif", System.Drawing.Imaging.ImageFormat.Gif);
else
MessageBox.Show("The Data In Clipboard is not as image format");
else
MessageBox.Show("The Clipboard was empty");
When I try the above snippet of code, it shows that the data in clipboard is not in image format.
I am trying to paste the contents of clipboard like this:
xlWorkbook.Sheets["Results"].Range("B" + D * 45).Paste();
But this doesn't work. It throws an error. I somehow feel it is due to the format of the clipboard contents.
I have been able to do it in VBA though.
Call InsPicFromClipbrd("B" & M * 45, TitleName)
This works great.
Could you please help me resolve this for my C# code?
Message 143 of 147
Hi @Rafal.Gaweda,
I also tried to save the screenshot as a.rtf file as follows:
RobotMapView.MakeScreenCapture(SSParams);
string fichier_sortie = "C:\\Users\\KOCH2401\\OneDrive Corp\\OneDrive - Atkins Ltd\\Desktop\\outjpg.rtf";
robotApplication.Project.PrintEngine.SaveReportToFile (fichier_sortie,IRobotOutputFileFormat.I_OFF_RTF_JPEG);
This does create the .rtf but it is blank. No screenshot. Just some text. Could you also please tell me why this is happening?
Thanks!
Message 144 of 147
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 145 of 147
It may not be a robot API topic directly but, how can I paste image from clipboard in a word file?
Thks in advance
Message 146 of 147
Stephane.kapetanovic
hi @Anonymous
You can find a code in VBA below. Take care to regularly inspect the clipboard.
Sub Copy_RobotCapture_To_WordDocument()
  ' Word
  Dim wordApp As Word.Application
  Dim wdDoc As Word.Document
  Dim paragraph As Word.paragraph
  Set wordApp = CreateObject("Word.Application")
  Set wdDoc = wordApp.Documents.Add
  ' Autodesk Robot Structural Analysis
  Dim RobApp As IRobotApplication
  Dim ViewMngr As IRobotViewMngr
  Dim ExportView As RobotView
  Dim ScPar As RobotViewScreenCaptureParams
  Set RobApp = New RobotApplication
  If RobApp.Visible = False Then
    Set RobApp = Nothing: Exit Sub
  End If
  Set ViewMngr = RobApp.Project.ViewMngr
  For i = 1 To ViewMngr.ViewCount
    If ViewMngr.GetView(i).Window.IsActive <> 0 Then
      ActiveViewNumber = i: Exit For
    End If
  Next i
  Set ExportView = ViewMngr.GetView(ActiveViewNumber)
  ' Do something
  Set ScPar = RobApp.CmpntFactory.Create(I_CT_VIEW_SCREEN_CAPTURE_PARAMS)
  ScPar.UpdateType = I_SCUT_COPY_TO_CLIPBOARD
  ScPar.Resolution = I_VSCR_2048
  ExportView.MakeScreenCapture ScPar
  Set paragraph = wdDoc.Content.Paragraphs.Add
  paragraph.Range.Text = " "
  paragraph.Range.Paste
  paragraph.Range.InsertParagraphAfter
  wordApp.Visible = True
  Set wdDoc = Nothing: Set wordApp = Nothing
End Sub
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
Message 147 of 147
mohamed_bareche
Salut @Rafal.Gaweda
Est-ce que c'est possible avec l'API de capturer les valeurs min/max en couleur rouge et vert sur un diagramme avec un code ?
