(API) C# Hepl: Problems create cross section rectangular in C#
chjpcoi
chjpcoi
Hello everyone
I am get start with Robot API
I want create cross section automatic, but I have problem that my code do not work
I tried to write in tow different ways but it still fails (red underline)
Option 1Option 1
Option 2Option 2
can you help me? thanks for your helps.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @chjpcoi
Example:
    Dim RLabel As RobotLabel
    Dim RLabelData As RobotBarSectionData
    Dim RLabelNSData As RobotBarSectionNonstdData
    Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_BAR_SECTION, "my_section")
    Set RLabelData = RLabel.Data
    RLabelData.Type = I_BST_NS_RECT
    RLabelData.ShapeType = I_BSST_RECT_FILLED
    Set RLabelNSData = RLabelData.CreateNonstd(0)
    RLabelNSData.SetValue I_BSNDV_RECT_H, 0.02
    RLabelNSData.SetValue I_BSNDV_RECT_B, 1
    RLabelData.CalcNonstdGeometry
    RobApp.Project.Structure.Labels.Store RLabel
Rafal Gaweda
chjpcoi
Hi @Rafal.Gaweda
Thank for your helps. it's so good
- I would like to know more, but how to know how to use the parameter for each different cross section type, I do not understand the description for parameter (pic 1 below)
Pic 1Pic 1
- I want to create cross section with different type sections, how do I do? (pic 2 below)
Pic 2Pic 2
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @chjpcoi
They should correspond to dimensions names on Your second screen shot \ robot window.
Rafal Gaweda
chjpcoi
Hi @Rafal.Gaweda
Thanks for your answer
Can you provide me a document explaining the relationship between screen shot 1 and 2 ?
