API C# Help Create view and screen Capture
chjpcoi
chjpcoi
Hello Everyone,
I have automatic view creation by API and view capture (code below), I have some following problems:
Code:
rbApp = new RobotApplication();
struc = rbApp.Project.Structure;
rbSelectPanels = struc.Selections.Get(IRobotObjectType.I_OT_OBJECT);
rbSelectPanels.FromText(dicStories[item]);
IRobotView3 viewRobot = (IRobotView3)rbApp.Project.ViewMngr.CreateView(IRobotViewType.I_VT_STANDARD);
viewRobot.Selection.Set(IRobotObjectType.I_OT_PANEL, rbSelectPanels);
viewRobot.Visible = 1;
viewRobot.Redraw(0);
viewRobot.Title = item;
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_FE_PANEL_CONTOURS, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_OTHER_GRID, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_OTHER_STRUCTURAL_AXIS, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_OTHER_STRUCTURAL_AXIS_DESCRIPTION, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_VALUES, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_SYMBOLS_UNIFORM_SIZE, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_SYMBOLS_PLANAR, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_SYMBOLS_LINEAR, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_SYMBOLS_CONCENTRATED, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_AUTOMATICALLY, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_DISTRIBUTION_REGIONS, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_STRUCTURE_SUPPORT_SYMBOLS, false);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_DISTRIBUTION_REGIONS, true);
viewRobot.ParamsDisplay.Set(IRobotViewDisplayAttributes.I_VDA_LOADS_VALUES, true);
rbSelectPanels.Clear();
rbApp.Project.ViewMngr.Refresh();
RobotViewScreenCaptureParams scPar = rbApp.CmpntFactory.Create(IRobotComponentType.I_CT_VIEW_SCREEN_CAPTURE_PARAMS);
scPar.Name = item;
scPar.UpdateType = IRobotViewScreenCaptureUpdateType.I_SCUT_CURRENT_VIEW;
scPar.Resolution = IRobotViewScreenCaptureResolution.I_VSCR_4096;
viewRobot.MakeScreenCapture(scPar);
rbApp.Project.PrintEngine.AddScToReport(item);
rbApp.Project.PrintEngine.SaveReportToOrganizer();
rbApp.Project.PrintEngine.SaveReportToFile(@"D:\2.API\API Robot\All\Pic tesst\" + item + nameCas[1] + ".rtf",
 IRobotOutputFileFormat.I_OFF_RTF_JPEG);
1. is there any way i can select the Maximize box of the newly created view ? (Pic 1)
Pic1Pic1
2. when i create auto view and use photo capture function the photo is black, is there any way to fix it using API?
(Pic 2)
Pic2Pic2
Thanks for your help.
Stephane.kapetanovic
hi @chjpcoi
First
viewRobot.Window.State = IRobotWindowState.I_WS_MAXIMIZE;
second
Have you tried with I_VSCR_3072, to put a 1 second sleep for current thread ?
if the case is to transform a bmp into jpeg and save it in a file, it is possible to do so without having to save it in the report.
Best regards
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
chjpcoi
Hi @Stephane.kapetanovic
Once again for me thank you very much for your help.
Have a nice day
