(API) C# Help: Coord. system local for Uniform Loads bars
chjpcoi
chjpcoi
Hello everyone
I am beginner with API Robot, my English is not good
I am using C# write to code for Robot,
I have code for uniform loads on the bars using coordantes sytem global :
  1.  int uniform = casname.Records.New(IRobotLoadRecordType.I_LRT_BAR_UNIFORM);
                        RobotLoadRecord loadRecord = (RobotLoadRecord)casname.Records.Get(uniform);
                        loadRecord.SetValue(System.Convert.ToInt16(IRobotUniformRecordValues.I_URV_PX), number1*1000);
                        loadRecord.SetValue(System.Convert.ToInt16(IRobotUniformRecordValues.I_URV_PY), number2*1000);
                        loadRecord.SetValue(System.Convert.ToInt16(IRobotUniformRecordValues.I_URV_PZ), number3*1000);
                        loadRecord.Objects.FromText(listElement);
but I have problems uniform loads on the Barusing coordinates sytem local, can you help me?
thanks for your help.
1234eddie
Hi @chjpcoi
take a look at this in the Robot Api documentation.
and this topic will maybe also helpfull,
https://forum.dynamobim.com/t/structural-analysis-for-dynamo-panel-surface-loads/34046/12
This is how i use it, by using the "identification numbers" of the properties.
In your case add just an extra LoadRecord.SetValue(11,....)
chjpcoi
Hi @1234eddie
Thanks you reply. I made it work very good
have a good night
1234eddie
@chjpcoi
Good to hear that it's working now.
Please mark this topic as "solved/Accept as solution".
Gr Edward
