(API) Addin: Walls To Loads
Romanich
Mentor Mentor
Message 1 of 9
Romanich
This addin will create loads from the selected walls.
Known limitations:
- only rectangular walls with the object type Contour will be converted
- openings are not taken into account
- if number and name of the load case is empty, load case Walls with number 99 will be created
- it is necessary to save/close/open the model after adding/modifications and start the addin to set object numbers in loads table (the reason is small bug in API)
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Replies (8)
Message 2 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Cool. Added to our list of addins
Rafal Gaweda
Message 3 of 9
nguyen_thang_nhat_quang
Hi Admin
Ii is very useful for me, But I am understanding how to use it?, Can you take short video, Please!
Thank you
Fan Robot Structural Analyse!
Message 4 of 9
Romanich
Xin chào,
https://youtu.be/RSv3MVzyumA
Message 5 of 9
MHDCACO
Hello, is it working for RSA 2024?
Message 6 of 9
Romanich
Hi @MHDCACO,
It should work.
Message 7 of 9
MHDCACO
I have transfered Partiton Wall from Revit to robot and when i use your application it just create a polyline. IWhat can be the issue?
Message 8 of 9
Romanich
Technically the linear load should be assigned to polyline. Please check if the correct material is assigned to the partition wall.
Message 9 of 9
MHDCACO
Yes It was the material. I've changed it but i notice sometime it works sometimes not.
