Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
(API) addin for merging bars
Rafal.Gaweda
Autodesk Support Autodesk Support
Message 1 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
addin for merging two bars  into one
Rafal Gaweda
Replies (31)
Message 21 of 32
Romanich
Hi @Rafal.Gaweda,
Could you please add a checkbox with on / off  Robot.Interactive parameter to the merge multiple bar add-in?
Roman Zhelezniak, P.Eng.
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 22 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Romanich
Attached.
Rafal Gaweda
Message 23 of 32
Romanich
Hi @Rafal.Gaweda,
It seems that you have attached an old exe file, without added option. Thanks in advance.
Message 24 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
HI @Romanich
Sorry.
Attached new one.
Rafal Gaweda
Message 25 of 32
gscSVFKN
Community Visitor
Community Visitor
Does it work in Robot 2020?
Message 26 of 32
Romanich
Yes, it works
Message 27 of 32
Can you please share me the code to merge bars
Message 28 of 32
Hi @Rafal.Gaweda ,
I need apply "merge bars" by VBA in my code, but this addin is in C#, I can not study well the commands for merge.
On what commands is the addin based to merge bars?
Thanks a lot.
Message 29 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Truly saying it is just replacing one bar node by another node number and deleting bars.
Of course this is not all. More tricky things about applying properties, merging loads etc.
Rafal Gaweda
Message 30 of 32
Hi @Rafal.Gaweda
Thanks for your feedback.
In my case, this is the initial structure:
The node 149 is the endnode for bar 34 and the start node for 33 bar. The node 266 is load node in bar 34.
My purpose is change the commun node 149 to the node 266, that is to say the node 266 must be the end node for bar 34 and the start node for bar 33.
I understand the process is something like this:
  1. Divide the bar 34 by node 266
  2. Merge the new resultan bar with bar 33, for this:
    1. delete both bars
    2. create new bar between nodes 266 and end node of bar 33.
    3. copy loads in new bar created, in my case there is not load in that new bar.
Is that so?
Could you help me with a draft code, please?
Thanks a lot!!
Message 31 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
I am not sure if I understood You. See my video below.
((API) addin for changing one bar node onto different one )
Rafal Gaweda
Message 32 of 32
Sorry I can not see the video,
