(API) addin for merging bars
Rafal.Gaweda
Autodesk Support Autodesk Support
Message 1 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
addin for merging two bars  into one
Rafal Gaweda
Replies (31)
Message 2 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
This attachment works on multiselection.
Rafal Gaweda
Message 3 of 32
t.sautierr
Hi rafal, it seems that these two APIs doesn't work. I have tried two merge 4 bars forming a cross (4 in one selection, 2 and 2, 1 only) but doesn't change anything, did I miss something?
First API does not recognize the selection
Second says merging finished but no change ...
Thanks.
Message 4 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
I do not undesrand.
Send me example robot file.
Try to use second addin.
Rafal Gaweda
Message 5 of 32
t.sautierr
The two APIs seem not to work withthis example.
Message 6 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
See below
Rafal Gaweda
Message 7 of 32
Hi Rafal,
Could you send the open project of merging addin ?
Message 8 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
Project attached
Rafal Gaweda
Message 9 of 32
Thank you very much!!!
Message 10 of 32
Jummybear
Does it work with Robot 2013?
After launching API it wrote me that robot doesnt start
Message 11 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes, it should work.
Please unregister all Robots you have on your comp (example how to do it in link below .../unregserver), register 2013 (.../regserver). IMPORTANT: Command Line must be started in Administrator mode.
You do not need to register rcom.dll
http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-problems/m-p/4891660/highlight/true#M218...
Rafal Gaweda
Message 12 of 32
Jummybear
I have modeled it in other way but i will try your suggestion (I have 2 different versions of Robot on my machine so i think it will help). Thanks.
Message 13 of 32
Does it work with RObot 2016? I get the message: "error-Robot not started".
Message 14 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes it works.
It seems you have more than one robot on computer so you need to register the correct one.
Check this thread, especially post 11
http://forums.autodesk.com/t5/robot-structural-analysis-forum/vba-excel-macro-for-any-object-geometr...
Rafal Gaweda
Message 15 of 32
joc
Nicely running
Message 16 of 32
Excellent, thank you. But the processing very slow?! More than 1 hour with two story 600m2 steel structure. It is possible facilitating the processing.Robot ST.png
Message 17 of 32
eoin.duggan
I have downloaded both merge addins but unfortunately they aren't working for me.
The merging multiple bars gives me a response stating that it has merged the bars in question but doesn't actually do that.
Merging bars addin states merge is 'not possible to merge bars because release defined at node XXX'
Would appreciate your help in solving this. Thank you.
File attached. Looking at roof merging beams clashing horizontal bracing.
Message 18 of 32
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @eoin.duggan
Please take look at post 6 in this thread.
In such case you need to delete releases on some bars.
Rafal Gaweda
Message 19 of 32
Hi Rafal.
Thank a lot.
Message 20 of 32
@Rafal.Gaweda good API, If is it possible to have the code please?
Thanks!
