(API) add diferencial temperature in all longitudinal beams deck with excel vba
Hi
How I do for add simple case with diferencial temperature of 15º  in all longitudinal beams deck ?
Regards
Márcio Teixeira
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Create a new load case
2. Define temperature load value in the load definition dialog
3. Select all beams you want to apply this load and copy their numbers to the list field of the load definition dialog
Artur Kosakowski
I show my code for the differential temperature:
Dim s As RobotSimpleCase
Dim l As RobotLoadRecord
Dim contador As Integer
Dim n As Double
Set s = robapp.project.Structure.Cases.CreateSimple(701, "Variação Diferencial Temperatura ", I_CN_TEMPERATURE, I_CAT_STATIC_LINEAR)
For contador = 0 To 13 Step 1
s.Records.New I_LRT_BAR_THERMAL           'it is correct for the differential temperature?
a = 2200101 + contador
Set l = s.Records.Get(1 + contador)
l.Objects.FromText a
l.SetValue I_BURV_PZ, 15                                 'and this line, how is?
Next
thank you again
Márcio Teixeira
rsousa_
 With simple change from tutorial,
Dim robapp As IRobotApplication
Set robapp = New RobotApplication
'   Generate new load case.
   Dim cas As IRobotSimpleCase
Set cas = robapp.Project.Structure.Cases.CreateSimple(robapp.Project.Structure.Cases.FreeNumber, _
"Case_1", I_CN_EXPLOATATION, I_CAT_STATIC_LINEAR)
'   Define load record types.
   cas.Records.New I_LRT_BAR_THERMAL
'   Get the first created load record
    Dim rec As IRobotLoadRecord
    Set rec = cas.Records.Get(1)
'Define the list of objects to which load will be applied.
   rec.Objects.FromText "7 8"
'   Define the type of thermal load.see robotbarthermalrecordvalues. You have to see if you want diferential temperature gradient in y or Z....
   rec.SetValue I_BTRV_TY, 15
'   Free previously declared variables.
Set rec = Nothing
Set cas = Nothing
Set robapp = Nothing
Is this ok for you?
Perfect !
Thanks a lot
Best Regards
Márcio Teixeira
