Announcements
Community notifications may experience intermittent interruptions between 10–12 November during scheduled maintenance. We appreciate your patience.
analysis of solids
analysis of solids
arq_rafael_p
Message 1 of 17
analysis of solids
arq_rafael_p
Hello, I am analyzing a solid that is formed by the element 4 elements, 1. is an angle acer, 2 steel reinforcements and 1 connector transmits a nodal load of 10 kg. to review the displacement gives me tremendous results, I'm omitting ?.
arq. rafael.p
Replies (16)
Message 2 of 17
Rafacascudo
Your support nodes are disconnected from the rest of the model!!!
Most of the time you can not ignore the analysis warnings!!
Have you already  tried a shell model ??
Rafael Medeiros
Message 3 of 17
arq_rafael_p
The CAD model is elbore export it to Robot through the SAT extension, one see in Robot generate its mesh nodes and assign load and support.
that way I can fix this advertensia that are not connected?
arq.rafael.p
Message 4 of 17
Rafacascudo
Well, I´m not familiar with solid models , but it seems to me ( if I understood you correctly) that the importing the solid into robot didn´t go very well
Probably the RSA official support  can help you better with this one
Rafael Medeiros
Message 5 of 17
StefanoPasquini6790
My personal suggestion is to strongly reccomand you to make a shell model. Solid model results can drive you out of road, with also bad management of the model and its warnings.
Follow my suggestion and the Rafacascudo one, this could be a good decision.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 6 of 17
arq_rafael_p
In parallel develop the project using panels but with results more posterior incoerentes mind, draw one more bar with reasonable results, the concern is that I can not analisar sirtos componetes as bar so the need for solids but the results I have left a bad taste.
With the results feel that the model is not behaving properly, as if each solid estubiera working independently and not hen whole.
They will have information they can share on this topic or application may allow me analisar a component of this type and to generate a memory of their behavior as I have to anlisar a good component.
Greetings.
Message 7 of 17
Rafacascudo
Rafael Medeiros
Message 8 of 17
Rafacascudo
The 1st thing you really need to do is find a good translator!!!!Very hard to understand with this one!!
Just write in spanish !!!
Rafael Medeiros
Message 9 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Supporting nodes are not considered by ACIS meshing
Do it this way:
File attached
Rafal Gaweda
Message 10 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
With better mesh - attached
Rafal Gaweda
Message 11 of 17
arq_rafael_p
Hello Rafa,
sorry for the bad translation, I appreciate the support, the file you sent me and have modified their loads my file I tried with the simulated results, Annex screen.
The model on the right is the model you sent me with modified loads and displacements.
The model on the left is the model we have developed to compare the above have different offsets and two warnings.
Ask the kneecaps connect them via a line, repeat this step with all the kneecaps and then perform an operation of solid which is me, what is the procedure with a single node (node with load).
Question, what happens when a solid is necessary to change their dimenciones. what would be the process.
You can give me your email
Atte. Arq.rafael.p
Message 12 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
I am very sorry , I do not understand spanish.
Please update your post with english translation because I am not sure if google traslate makes it correct.
PLease attach \ send Robot file(s) also.
Rafal Gaweda
Message 13 of 17
arq_rafael_p
Hello Rafa,
https://www.dropbox.com/sh/srhvj11ev7ziivr/AACAFEOgO1ARnLpFiZQjA4tha?dl=0
Atte. Arq.rafael.p
Message 14 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
move node 1098 onto node 5081
Rafal Gaweda
Message 15 of 17
arq_rafael_p
NO RAFA,
TO CREATE THE MODELING, ROTULAS APPROPRIATE BY THE LINES AND LOAD FROM A NODE, SEND ME A VERY STRANGE MESSAGE.
"Z STEERING SHAFT OF LOCAL SYSTEM IS REVERSE"
"NODES ARE SEPARATED ROTULAS"
ELEMENT AND TWISTED. ANALYSIS AND STOPS AS THIS CORRECT?
ARQ.RAFAEL.P
Message 16 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Either use previous simplified model
or
remove from model these parts:
or use http://www.autodesk.com/products/simulation-mechanical/overview instead of Robot.
Rafal Gaweda
Message 17 of 17
arq_rafael_p
RAFA YOU READY ERROR.
THAT DIFFERENCES BETWEEN A ROBOT GRANDDES FEATURES AND MECHANICAL SIMULATION.
ATTE. ARQ.RAFAEL.P
