Analysis error 2D - 3D?
Max-88
Message 1 of 9
Max-88
I need a bit of help, please.
I have modeled a portal frame building in a 3D model and then one portal in a 2D model (one portal from the 3D frame).
For a simple load case of uniform distributed permanent load the results are very, very different.
From a direct comparison with another software, the 2D model results seem to be right (almost).
Could anyone look into the 3D model and try to shed some light on the issue?
Thanks.
Max
2D frame loads and bending moment results - checked with another software, OK'ish
Same portal from the 3D frame - different results
Replies (8)
Message 2 of 9
napooil
I think. In your 2D model. Support in middle of Structure it is Roller Support. but in 3D model it is Pinned support.
Message 3 of 9
Max-88
Thanks for looking.
The pinned support is my attempt to emulate the 2D behavior in the 3D frame.
If the pinned support was to be replaced with a roller support, the remaining of the frame would "interact" with the portal and the results cannot be compared with the 2D frame - simply change the support type and compare.
cheers
Message 4 of 9
napooil
Message 5 of 9
Max-88
Getting somewhere....
Changed the support to XZ only, results are still miles away.
cheers
Message 6 of 9
napooil
Message 7 of 9
paul.bassLH
Your purlins on roof are fixed in your 3D model.
If you change the support in 3D model (only Z), you remove your supports on purlin 240 and 241 (???) and add releases on purlins:
modified 3D modelmodified 3D model2D model2D model
The remaining difference is the self weight of purlins i think.
Regards
Message 8 of 9
Max-88
THANK YOU.
Message 9 of 9
Max-88
Thanks lots, the way I added supports were the problem.
Thanks again for helping.
cheers
