Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need a bit of help, please.
I have modeled a portal frame building in a 3D model and then one portal in a 2D model (one portal from the 3D frame).
For a simple load case of uniform distributed permanent load the results are very, very different.
From a direct comparison with another software, the 2D model results seem to be right (almost).
Could anyone look into the 3D model and try to shed some light on the issue?
Thanks.
Max
2D frame loads and bending moment results - checked with another software, OK'ish
Same portal from the 3D frame - different results
