Advanced nodal support
Grohl
Grohl
Hi.
I've tested three slabs with different nodal supports.
1. Pinned support
2. Pinned support with dimension a=1000mm b=1000mm h=1000mm
3. Pinned support with column a=1000mm b=1000mm
Why is not support 2. giving me reduction of forces like number support 3?
See attached files
Pawel.Pulak
Autodesk Support
Autodesk Support
Because support type 2. is intended only to enable some approximative view of the dimensions of spread footing when "Support shapes" are activated in the display of attributes.
Useful when displaying some plan of foundations.
Reduction of forces is not made for such support.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
