Add material to arc.
Hello
I have some problems to add timber to my arc. I have made an arch-line and I have managed to attach several short beams to shape an arch to this line. But this arch is 80 meters long and 15 meters high, and I only want my arch to be parted in three segments. This will give the three beams an curvature, but i don't know how to add the beam to my arch-line.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please c heck: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Modeling-a-Curved-Roof/td-p/3782066
Artur Kosakowski
I have gone through the link, but I still can't get my wood beams curved. They will only place themselves as straight beams. I need them to be long and curved. Can you tell me how... Please
If you want to do it with bars then they CAN ONLY be made from straight segments.  If you want a true curved member, you need to model the arch as a shell element (not a cladding).  You achieve this by defining an arc then extruding it to the required length.
Tony
Can you tell me more exactly how, I'm pretty new to this program.
like this,
Then change the cladding into a panel of desired thickness, then mesh.
Tony
Thank you. This was very helpful, no I can proceed on my project. Smiley Happy
