Add load to cladding through api
tiromos
tiromos
I have  developed the following code which generates a cladding in vba
Option Explicit
Sub DrawCladdings_Skeleton()
Dim RobApp As New RobotApplication
'Check if Robot is running
If RobApp.Visible = False Then '
MsgBox ("OPEN ROBOT FIRST!")
Exit Sub
End If
RobApp.Project.New I_PT_SHELL
RobApp.Interactive = False
'Draw the claddings
Dim monobjet As RobotObjObject
Dim moncontour As New RobotGeoContour
Dim monsegment() As New RobotGeoSegmentLine
'Start of loop
ReDim monsegment(1 To 4)
monsegment(1).P1.Set 0, 0, 0
moncontour.Add monsegment(1)
monsegment(2).P1.Set 1, 0, 0
moncontour.Add monsegment(2)
monsegment(3).P1.Set 1, 1, 0
moncontour.Add monsegment(3)
monsegment(4).P1.Set 0, 1, 0
moncontour.Add monsegment(4)
moncontour.Initialize
Set monobjet = RobApp.Project.Structure.Objects.Create(1)
monobjet.Main.Geometry = moncontour
monobjet.Main.Attribs.Meshed = False
monobjet.Main.Attribs.DirZ = 0 ' axe local
monobjet.Main.Attribs.SetDirX I_OLXDDT_CARTESIAN, 1, 0, 0
monobjet.Initialize
monobjet.Update
Dim rbar As Variant
Set rbar = RobApp.Project.Structure.Bars.Get(1)
rbar.SetLabel RobotOM.IRobotLabelType.I_LT_CLADDING, "Two-way"
moncontour.Clear
Set monobjet = Nothing
Set moncontour = Nothing
ReDim monsegment(1 To 1)
Set monsegment(1) = Nothing
'End of loop
RobApp.Interactive = True
End Sub
I want to apply a uniform load, but I couldn't find something similar. Any help would be greatly appreciated. Thanks in advance.
Stephane.kapetanovic
salut  @tiromos
Vous pouvez trouver des exemples similaires dans le guide de démarrage de l'API Robot dans le répertoire SDK
Sub CreateCladding()
  Dim RobApp As RobotApplication: Set RobApp = New RobotApplication
  If RobApp.Visible <> -1 Then
    MsgBox ("OPEN ROBOT FIRST!"): Set RobotApp = Nothing: Exit Sub
  End If
  Dim points As RobotPointsArray
  Set points = RobApp.CmpntFactory.Create(I_CT_POINTS_ARRAY)
  points.SetSize 4
  With points
    .Set 1, 0, 0, 0
    .Set 2, 1, 0, 0
    .Set 3, 1, 1, 0
    .Set 4, 0, 1, 0
  End With
  With RobApp.Project.Structure.Objects
    .CreateContour 1, points
    With .Get(1)
      .SetLabel I_LT_CLADDING, "Two-way"
      .Update
    End With
  End With
  Dim CaseLive As RobotSimpleCase
  Set CaseLive = RobApp.Project.Structure.Cases.CreateSimple(1, "Live", I_CN_EXPLOATATION, I_CAT_STATIC_LINEAR)
  With CaseLive.Records.Create(I_LRT_UNIFORM)
    .SetValue I_URV_PZ, -10000
    .Objects.FromText 1
  End With
  Set RobApp = Nothing
End Sub
 Cordialement
Stéphane Kapetanovic
don't forget to accept the solution and leave a < like !
tiromos
The key word being "similar", I have already tried to use the related code from getting started:
Dim LoadRecord As RobotLoadRecord
Set CaseLive = str.Cases.CreateSimple(2, "Live", I_CN_EXPLOATATION,
Uniform = CaseLive.Records.New(I_LRT_UNIFORM)
Set LoadRecord = CaseLive.Records.Get(Uniform)
LoadRecord.SetValue I_URV_PX, 0
LoadRecord.SetValue I_URV_PY, 0
LoadRecord.SetValue I_URV_PZ, -10000
LoadRecord.Objects.FromText (1)'
But couldn't make it work
try my code first as it is consistent and concise
tiromos
1. Yes, it does work, thank you very much. Could you please add one more load and one combination to the code?
2. try my code first as it is consistent and concise -> truth be told, my code seemed like black magic to me.
1 - What loads?  (API) Load Combinations , Contour Loads , Linear Load 2P
2 - Your code creates a panel as well except the cladding label. Don't worry. If it's a panel without curves, the CreateContour method is simpler and faster.
