actual reinforcement of reinforced concrete elements Problem
4 REPLIES 4
473 Views, 4 Replies
when you choose to beam and then click the icon
my Autodesk Robot 2014 give my info   :element is not included in the actual reinforcement modules. Gamma angle of the beam is not a multiple of 180 degrees.
i have no idea, what is wrong.
Please help me 🙂 I can speak in polish, english and german.
4 REPLIES 4
Rafal.Gaweda
Please provide us with the file and the beam number to check
Rafal Gaweda
in reply to: Rafal.Gaweda
OK.
here you go. beams 79 and 80.
btw
I didn't see Connection column-beam (column - HEB profile and beam - RK (square) profile like 200x200x6)
i can only I-beams connection create
Artur.Kosakowski
btw
Only I sections are supported for this connection type.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
in reply to: Artur.Kosakowski
I changed beams from 20x65 to 65x20 and remove gamma (in properties), but still doesn't work.
and now is: beam is not properly defined (the angle of> 80)
