Access to autoarch.err was denied
Please can someone help me identify this error.
Is there a problem with my model?
James
Pawel.Pulak
Autodesk Support
Autodesk Support
No, it is not related to the model itself.
It can be related to the access to the model or to Robot configuration.
Check the forum post linked below - may be some explanation given there fits to your case:
http://forums.autodesk.com/t5/robot-structural-analysis/autoarch-err-error/m-p/3302081#M2321
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Artur.Kosakowski
Autodesk Support
Autodesk Support
Corrected in 2017 SP1.
Artur Kosakowski
I'm using Robot 2016. It appears when trying to save the model. What does it mean and is it ok if I ignore it?
thanks
Artur.Kosakowski
Autodesk Support
Autodesk Support
If the model has been saved then I think you can ignore it.
Try to work with only one Robot running at the time.
Artur Kosakowski
