I have generated a new model in Robot 2017, however I cannot view the model except in 2D plan view. I have also tried the 2016 version. I am running the software on a surface pro 3, do you have any advice as to how to fix this issue?
Solved by Mohammed_Ata. Go to Solution.
For module Building Design, there are 2 windows: one for 2D plan XY and the other is the for 3D view
If the problem is existing, try to go to another template/module from geometry >> structure type
Thanks. I've not used Robot for a number of years and wasn't aware of this function.
