3D Connection design
Hi all,
I am designing a playground structure consisting of cubes made off CHS sections.
I want to design the connections which need to be welded but the problem is that Robot allows me to define connections consisting of member at the same plane only (2D). See an example on the screenshot bellow:
Is there a way design that connection in once or should I pick the bars in pairs? Any ideas?
Thank you in advance.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the sketch of the connection you want to create? Is it going to be welded, are there any additional plates etc.?
Artur Kosakowski
Hi Artur and thank you for your reply.
If you look at the image I uploaded previously the 3 highlighted members, which are three edges of a cube, are an indicative example.
The connection needs to be fully welded with no plates provided preferably.
Many thanks.
