2D frame to Eurocode - value of XLT
13 REPLIES 13
Message 1 of 14
626 Views, 13 Replies
I'm designing a portal frame to BE EN 1993-1. My rafters fail the global stability checks for buckling resistance and bending & axial compression. I think the problem is in the calculation of chi LT (XLT in robot). Robot gives me values of XLT=0.18, while my hand cals show XLT=0.975. I attach my full calcs note
Any ideas would be greatly appreciated. Thanks
13 REPLIES 13
Message 2 of 14
Romanich
Hi @Anonymous ,
Could you please also attach your hand calculations?
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 14
in reply to: Romanich
Hi Romanich,
My calculated XLT was actually 0.952, but still much higher than the one calculated in robot. See attached
Message 4 of 14
Romanich
Hi @Anonymous ,
Mcr and lateral buckling curve are different. Have you tried to input these values manually and check the results?
Roman Zhelezniak
Message 5 of 14
Thanks for your help @Romanich ,
Changing  the Mcr and buckling curve helped. My XLT is still different, but this must be due to  a different value of beta taken by Robot.
Message 6 of 14
@Romanich ,
Just wondering why the Mcr wasn't calculated correctly? My portal frame is rather standard, so I'm surprised with the result.
Thanks, Magda
Message 7 of 14
Romanich
Hi @Anonymous ,
Could you please attach your Robot model?
Roman Zhelezniak
Message 8 of 14
Hi@Romanich ,
Please see attached. This is the one with Mcr changed manually. Thanks
Message 9 of 14
Romanich
Hi @Anonymous ,
Try to zip model first or check this topic
https://forums.autodesk.com/t5/robot-structural-analysis-forum/sending-bigger-files/td-p/3795062
Roman Zhelezniak
Message 10 of 14
Message 11 of 14
Romanich
Hi @Anonymous ,
Also I would kindly recommend to always check warnings:
Roman Zhelezniak
Message 12 of 14
Thanks @Romanich
I'm still a bit confused with all the lengths that need to be specified (Ly; Lz; Lcr,y; Lcr,z; Lcr,low) and how they are taken into account in calculations. Are there any guidelines on how buckling calcs are dealt with in Robot?
I.e. I've changed  Lcr,low to =1.64m, beta to =0.75, lambda lt,0 to =0.4 as you suggested and I'm still getting different (than my hand calcs Mcr=1588) value for Mcr=4300.
Warnings were due to the haunch specified in the model, I have deleted it now.
Message 13 of 14
Romanich
Hi @Anonymous ,
Please also check these topics:
https://forums.autodesk.com/t5/robot-structural-analysis-forum/purlins-design-lateral-buckling/m-p/3763998
https://forums.autodesk.com/t5/robot-structural-analysis-forum/lateral-buckling-critical-moment/m-p/3253094#M1701
Roman Zhelezniak
Message 14 of 14
Thanks for suggestions @Romanich
