Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
1-way slab not working
6 REPLIES 6
aecc_danda_2
238 Views, 6 Replies
It seems as though the 1-way slab is not transferring the loads onto the central beam correctly, as the bending moment results are not correct. May someone please help me resolve this issue in the structural model?
I am getting the following error:
"The load has not been distributed correctly - There are no objects or elements carrying the load overlap"
Whilst simply using the default 1-way panel
Thank you.
6 REPLIES 6
Hi
Share zimpped model version for verification
Krzysztof Wasik
Thank you very much. Please find the model attached.
Please also send a response to thomas@danda.com.mt
Thomas
aecc_danda_2
in reply to: aecc_danda_2
Zip attached
Hi @aecc_danda_2
Loads distribution problem is caused by beams not perpendicular/parallel to load distribution direction
Error with load distribution is caused by loads not applied to objects in Wind load case. They should be deleted.
I would recommend
define Deck slab two way calculation model and apply it to slabs.
Ignore beams  288 299 300 308 309  while load transfer from slab
Load distribution should be better after modifications.
Refer to modified model.
Krzysztof Wasik
Simau
in reply to: Krzysztof_Wasik
@Krzysztof_Wasik @aecc_danda_2
No such problem with Robot 2023
No warning message
M. Agayr
Krzysztof_Wasik
in reply to: Simau
HI @Simau
Warning message regards forces not applied to objects in case 6. In fact it is not incorrectly distributed load (warning is not necessary) . Forces from case 6 results in zero loads and zero results are presented for case 6. Results for case 6 are correct. No warning is needed (so it was removed).
Krzysztof Wasik
Technology Administrators
