Cumbrera inclinada en Revit
noeelianr
1.452 Vistas
5 Respuestas
Mensaje 1 de 6
noeelianr
Buenas,
He realizado esta cubierta inclinada por perímetro y, como podéis ver, una de las cumbreras la hace inclinada... he intentado editarla, crearla por extrusión, por masa... y ha sido imposible.
¿Cómo la resolveríais?
En el alzado he dibujado unos planos de referencia que explican por dónde debería ir esa cumbrera.
Gracias 🙂
@noeelianr para una mayor claridad @joaquim.moral ha editado el título original: Cumbrera inclinada.-
Recuerda consultar cómo escoger el mejor título para tu post. ¡Gracias por participar!
0 Me gusta
Soluciones aceptadas (2)
1.453 Vistas
5 Respuestas
Respuestas (5)
Mensaje 2 de 6
Cool. Maybe you broke Revit.  I have no idea how you got there.  Can you replicate it?
Mensaje 3 de 6
@noeelianr wrote:
Buenas,
Gracias 🙂
I have made this roof sloped around the perimeter and, as you can see, one of the ridges makes it sloped... I have tried to edit it, create it by extrusion, by mass... and it has been impossible. How would you solve it? In the elevation I have drawn some reference plans that explain where that ridge should go. Thank you
Because edges 1 and 2 are not parallel.
0 Me gusta
Mensaje 4 de 6
Solución aceptada
You CAN get there with non-parallel walls if you don't define the slope in the Roof Sketch. Instead, leave it flat (e.g. no define slope segments) and use Modify Sub-Elements to place your uniform height ridges via "Split Lines" .
0 Me gusta
Mensaje 5 de 6
Solución aceptada
0 Me gusta
Mensaje 6 de 6
noeelianr
Hey!
For those who wonder how i did it, im just trying to attach a screen capture.
I know edges 1 and 2 are not parallel, but what i think it should do is to modify the slope along that section, but not to make a sloped ridge. (although i've invested so much time on that little thing now I feel I know nothing...)
And,   did you create that with the tool roof of floor?
Anyway, I'm still trying to solve it with all your comments, trying to focus on the height in the final edge insted of slope and... we'll see!
Thanks so much for your comments and your time.
and if anyone knows how to solve it, it'd be a great help!
