You may want to check the active view, its Parameters, and Visibility settings.
alikdi26
Message 1 of 13
alikdi26
None of the created elements are visible in 3D View: analytical model View. You may want to check the active view, its Parameters, and Visibility settings.
why there isnt showing any highlights when i applying hosted load while analyzing
Replies (12)
Message 2 of 13
mphungDCHNW
You may want to check your Visibility settings the categorie your trying to insert might be turned off or unchecked
Message 3 of 13
alikdi26
i cant see any analytical plan/view in my rvt 2020 version i enabled in vg options and i tried to make it by duplicating view but when applying template settings there is also no option to select structural
i tried it in structural template
in the abv photo there is only floor plan
but in structural plan also looks same situation
i cant see analytical in  view templates too to toadd new analytical templt
\screenshot attached dow
how can i do this help me to fix it
Message 4 of 13
mphungDCHNW
Try changing to medium / course along with changing the view to realistic
Message 5 of 13
mphungDCHNW
Click on view then click on " view templates" select "apply template to current view" then go turn on analytical.
Message 6 of 13
mphungDCHNW
Message 7 of 13
Create new Structural plan, set Discipline to Structure, VG > Analytical tab and turn on Analytical categories.
Message 8 of 13
alikdi26
 look sir , i cant add analysis isolated here becoz i dont have such a drop down  in view temp to add
nb: i have robott analysis already in pc
Message 9 of 13
mphungDCHNW
If you have duplicated a Arch/Struct view just turn the analytical on and you will see it in the Setting you listed in the photo..
Message 10 of 13
alikdi26
did it thanks
Message 11 of 13
mphungDCHNW
Did it work?
Message 12 of 13
alikdi26
yes
Message 13 of 13
linda_salihu
Observer
Observer
Anyone know which view is the active view?
