blend object is not visible in section cut view
muchlisprayoga89
muchlisprayoga89
hello, I'm having trouble when I want to make rebar on the top face of the pier because the outline of the pier is not visible in the section cut view, as in the picture I attached below, I need a solutionDETAIL VIEW.pngSECTION CUT VIEW.pngVG PROPERTIES.png
mphungDCHNW
If your trying to blend a complex object shape the sections/reference has to be Parrell to the view itself.
