When I export from .rvt to .nwc file, the concrete family is moved
filippialbuquerque
Message 1 of 9
filippialbuquerque
Hi there.
I'm having some serious trouble with this, if anyone have any suggestion I would be very greatful.
I'm working on a reinforced concrete bridge model at Revit. Each concrete element is modeled in a separeted rvt file and then we have a central file with all the elements liked togheter where we make up the bridge.
I need to export the entire model to a .nwc file (export the file with a lot of rvt links), but  when I do this, Navisworks shows some element in a very diferent position when compared to Revit.
I'm stuck with whis for several days and can't find a solution.
I attached two images: one from Revit screen before exporting and another after exporting to Navisworks. We can see that one link remains at the same location and the other has just been moved.
Thank you so much for the attention.
Replies (8)
Message 2 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @filippialbuquerque
Please try the same with Revit 2021 and Navisworks 2021.
If the issue persists, please post Your example Revit file.
Rafal Gaweda
Message 3 of 9
Mohamed-Nassar
1- check the Export setting Used
2- check the Coordinates System in this files they are must be the same shared coordinates or Project base point
3- Same Version for Revit and Navisworks
Any Additional info tag me
Best Regards,,
Mohamed Nassar
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Message 4 of 9
filippialbuquerque
Hi @Rafal.Gaweda , than you for your reply.
I don't have access to Revit or Navis 2021 today, because my workstation is running with Revit and Navis 2020. But I will try this solution on another computer and present the results here.
By the way, I attached the files, I used both Revit and Navis 2020.
Thank you!
Message 5 of 9
filippialbuquerque
Hi @Mohamed-Nassar , thank you for your reply.
I tried different export settings and nothing worked for me.
I tried the coordinate as internal and shared as well.
These two linked files have the same origin and I used the same version for both softwares, 2020.
I attached my files in the post above.
I found this very strange ...
Thank you !
Message 6 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
NWC from Revit 2021.1 attached.
Rafal Gaweda
Message 7 of 9
Mohamed-Nassar
Some times need for updates software to solve problems like this,
Update your software and try, i am sorry for you also i have not 2020 in my machine but check last updates for your software update me with latest.
Best Regards,,
Mohamed Nassar
Message 8 of 9
filippialbuquerque
Fantastic! I would never think that.
Thank you very much
Message 9 of 9
filippialbuquerque
It seems that it really was the problem. Thank you!
