What approach should be followed for large plant modeling with many buildings in Revit?
ranga.narasimhan
ranga.narasimhan
Hi all,
We have a project where we have several steel buildings. We want to model each building as a separate revit model.
I understand that when we link multiple revit files together, it is hard to position the origins at our wish.
Since we need each steel building to be located at a specific (plant) grid co-ordinates, what is the best approach to do this task?
If it was autocad/inventor, I would create a layout sketch and use it in all individual files as a common background/xref. So that, when they come together, they all go in the right place.
How to do this in Revit?
Ranga
Accepted solutions (4)
You can use shared coordinates in revit, this way you work with several files linked and oriented to a base point.
Set up the first linked file with main grids, levels, coordinates as well as templates, schedules and basic families (even your Autocad/Inventor as reference in this file). Then you will share this file with your team members; each member will create another file containing a building/zone which is detached from the 1st file. Then you can use an empty file to link everything together as a main file for coordinate, check clash and so on. Each model file also can be used as a link for the other model file to check surrounding areas when modelling.
ranga.narasimhan
Also, the following YouTube videos gave very good explanation about revit co-ordinate systems.
https://www.youtube.com/watch?v=tZL3tjNvVIY
https://www.youtube.com/watch?v=zVfZ5LIOK6o
I strongly going through videos sequentially for any beginner like me. Help a lot.
-Ranga
ranga.narasimhan
One more nice video link to watch. This one gives kind of real world issues that a professional BIM guy might come across.
-Ranga
https://www.youtube.com/watch?v=cKvIIJd9hSI
