Weekly New Knowledge Network Articles | Revit Structure
matthew.d
Alumni Alumni
matthew.d
Question: Where can I find a list of the Autodesk Knowledge Network support solutions that were created and/or updated for Revit Structure?
Subscribe to receive updates for new Revit Structure Knowledge Network articles.
For more updated solutions, check out the AutodeskHelp Blog!
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
matthew.d
January 2016
Week 1:
Carbonite stopping Revit from syncing
Customizing arrowhead of the stair path symbol
Revit 2015: UR11 breaks Revit Server
Wall opening height is missing in Revit dimensions
Week 2:
Changes to a point cloud .rcp file are not displayed in Revit after the file is reloaded
IFC export doesn’t consider mapping file
Inconsistencies at dimension references at the usage of “Cut geometry” / “Uncut geometry” commands
Missing drawing lines when importing CAD file into Revit
Reinforcement elements are not shown in section views that have a segmented section line
Revit | Toolclip video doesn’t work anymore
Revit: Override graphics in view by category for Revit links not propagated to visibility/graphics o...
Transmitted Model dialog unexpectedly appears after file from eTransmit is resaved in Revit Server
Week 3:
Buildingbook extension - room part quantities calculation and phasing
Door tag label in Revit get shifted when rotating
Energy Analysis error: “… Unable to analyze…” (Revit)
Energy Cost Range tab missing from Results & Comparison dialog
Error: Energy Analysis - “There has been an unexpected problem. Unable to Analyze?
Render command is grayed out
Revit: Wall sweep of architectural wall appears in the structural discipline
Some or all colors in a color scheme are suddenly changed (Revit 2016 R2, Revit LT 2016 R2)
Surface representation component in Revit family gets cut unpredictably
Using formula to define roof slopein Revit
Week 4 - 5:
An AutoCAD dwg imported in Revit results in a wide zoom extents
Exporting assets from Autodesk Revit to Building Ops
File won’t synchronize
Hidden areas and room separation lines in Revit project
Hidden subcategories in Revit view
No global binding for HTTP prevents installation of Revit Server
Properties palette shows two “End of Referenced Element” parameters for structural braces
Proxy Server and domain exceptions for Autodesk A360 services
Revit Server Installation failed
Revit: The user interface of Revit may turns to Chinese
Solon tab is blank for Windows 10 systems
Structural beams disappear from floor plan view after being joined
Wrong program opens when accessing help from Revit
Matt DiMichele
matthew.d
Archive
December 2015
Week 1:
Beam and Column connection issue in Revit
Week 2:
Built in parameters in Electrical equipment family template
Collaboration for Revit Error: The current user doesn’t have the write access to the document…
Foundation slab area property is not exported to DWF/ DWFX format
IFC duct elements missing in Revit view
Revit 2016 R2: Unable to make changes in color scheme
Revit: Hang when printing to PDF with 2016 R2
The Select Views window is blank when gluing a model from Autodesk Revit
Week 3:
Assembled stair carriage and stringer support parameters are mixed up in Russian
Auto ceiling does not detect boundary comprised of walls and structural columns if columns are large...
Creating MSP out of EXE for Revit 2015 UR10
Exporting Revit families with SDNF-Export
Navisworks: How to use Switchback with a Collaboration for Revit model
Non-rectangular crop region and interior fill of room affect visibility of 3d components in sheet vi...
Revit overwrites instance parameters when swapping families
Revit: How to find the Release 2 update for 2016 for Eflex customers
UK English Revit includes American terms for beams' Structural Usage property
Values for Top and Base are not displayed for balusters created in Revit in a different language
Week 4:
2016: How to Complete a Clean Install and Uninstall of Revit products
Auto-ceiling detects boundary of walls and structural columns but does not place ceiling
Extra linework printed from curved walls over 180 degrees in perspective views
Hidden line display for custom line style controlled through wall hidden line subcategory
Loading unused sizes of universal columns into an upgraded file causes existing column parameters to...
Revit: Fill pattern is not printed
Revit: Lines Missing in DWG Export
Revit: Software emulation in use when in Citrix XEN App environment in Windows Server 2012
Vault Servers Revit Indexing Troubleshooting Checklist
Matt DiMichele
