Knowledge articles written by our Revit support team to resolve the problem on your own. There're a couple of incidents reported, do take a look at them for possible workarounds.
Published Date |
Summary |
Knowledge Article |
Incident Logged |
31-Jan-23 |
When collaborating in a workshared Revit model, an editing request to relinquish ownership of an element does not get received until after syncing. |
Editing requests in a workshared Revit model do not appear until after syncing |
No |
31-Jan-23 |
Users reported that is displayed when using Trim Extend command on Area Based Load Boundary Lines |
"Can't keep elements joined" error with Area Based Load Boundary Lines in Revit |
Yes |
31-Jan-23 |
Users reported that face based objects connected to a duct flip to the other side of the hosting duct when editing the duct length. |
Face based object flips to the other side of its MEP host when changing the host element in Revit |
Yes |
30-Jan-23 |
Users reported that the graphics are degraded in highly zoomed views with "Realistic with Edges" visual style in Revit. |
Degraded graphics in views with "Realistic with Edges" visual style in Revit |
Yes |
30-Jan-23 |
View Filter with OR rule does not work on linked models in Revit if two or more categories are included from the category list that do not share the same parameter that is being filtered against. |
View Filters with OR rule does not work on linked models in Revit |
Yes |
28-Jan-23 |
"An unrecoverable error has occurred" message appears when working with model in Revit. |
"An unrecoverable error has occurred" when working with model in Revit |
No |
28-Jan-23 |
Cloud workshared Revit model freezes and closes randomly |
Yes |
27-Jan-23 |
How to change unit symbol in Cost per Area unit in Revit? |
No |
27-Jan-23 |
Users reported that beams in truss will be deformed after copying them between grids. |
Beams in truss will be deformed after copying them between grids in Revit |
Yes |
27-Jan-23 |
How to add Revit Project Template and Family files to the Autodesk Construction Cloud or BIM 360 for future cloud projects? |
How to add Revit Project Template and Family files to the cloud for future projects |
No |
27-Jan-23 |
Non-hosted terminal equipment is unexpectedly shown as hosted when placed in model by clicking on duct/pipe/etc. in Revit. |
Yes |
27-Jan-23 |
User reported that it is not possible to export elements to IFC as IfcDistributionSystem from Revit. |
Unable to export elements to IFC as IfcDistributionSystem from Revit |
Yes |
26-Jan-23 |
Help improvement regarding the behaviour of linear elements/families (beams, columns) in Revit. |
Help regarding the behaviour of linear elements/families in Revit |
Yes |
26-Jan-23 |
A Sprinkler doesn't move with pipes when everything is selected and moved vertically in Revit. |
Sprinkler doesn't move with pipes when everything is selected and moved vertically in Revit |
Yes |
24-Jan-23 |
Model positioned at Incorrect levels when linking IFC file in Revit 2023 |
Yes |
24-Jan-23 |
MTEXT block in DWG exported from Revit is displayed in another colors than in Revit. |
MTEXT block in DWG exported from Revit is displayed differently |
Yes |
24-Jan-23 |
Users reported that exporting a Revit model with many rebar elements to IFC 2x3 format, the performance is very slow. |
Slow performance when exporting a model with many rebar elements from Revit to IFC |
Yes |
23-Jan-23 |
Users reported that calculated parameter values in label families display with wrong unit settings in Revit projects. |
Calculated parameter value in a label family displays with wrong unit settings in Revit projects |
Yes |
23-Jan-23 |
Spiral pile reinforcement with a variable pitch as a one position in Revit |
No |
23-Jan-23 |
Unable to apply a graphic override on the display of a certain family in a Revit view. |
Unable to apply graphic override of a view filter to a custom family in Revit |
No |
23-Jan-23 |
How to publish all models of a cloud worksharing project with one click now, that the "Manage Cloud Models" button has been removed from Revit 2023. |
Yes |
21-Jan-23 |
How to associate the visibility of a Label with Yes/No parameter type in Revit? |
How to associate the visibility of a Label with parameter type in Revit |
No |
20-Jan-23 |
"Eternal Tools - External Tool Failure" message when starting Revit installed via Custom Install through Products and services in Autodesk Account. |
"Eternal Tools - External Tool Failure" message when starting Revit installed through Custom Install |
No |
20-Jan-23 |
The joining of two slabs with slope and a foundation at the point of flexion, cannot be realized in Revit. |
Yes |
20-Jan-23 |
Current size of the MEP fitting is changing after using align feature in Revit. |
Standard size of the fitting changes after using align feature in Revit |
No |
20-Jan-23 |
Users reported that it is not possible to generate analytical elements automatically connected to each other in Revit. |
Unable to generate analytical elements automatically connected to each other in Revit |
Yes |
19-Jan-23 |
When editing/modifying a wall assembly, a error message of "One or more dimension references are or have become invalid" in Revit. |
Yes |
19-Jan-23 |
Is it possible to customize Roombook and Areabook reports in Revit? |
No |
19-Jan-23 |
When the boundary box of objects of some Revit categories is within the sketch of a plan region, the object is displayed even outside the plan region sketch. |
Yes |
19-Jan-23 |
Slow performance after running Dynamo from Revit. |
No |
18-Jan-23 |
How to control the folder permissions of multiple companies when linking Revit Cloud Worksharing Models in ACC? |
No |
18-Jan-23 |
How to use solar analysis in Revit to determine location for solar panels? |
Solar analysis in Revit to determin location for solar panels |
No |
