Warning: "Elements will be deleted" when moving objects via click and drag method in Revit
Musa.ali
Musa.ali
This is really frustrating, i cant move section/objects without them being deleted. I saw that this topic had been adressed by Autodesk but theyre "solution" didnt really do anything..
In theyre solution one can move the objects through nudge and move tool but if i for exampel have moved a connection 40 mm in one direction i would to move the corresponding section the same distance instead of using nudge/arrow key. Has anyone come up with a soluton to this? Beacuse there "solutuion" isnt really a solution.
I have tried moving section/object with the move tool in other projects and i havent had any problems before now.
Revit 2021
ennujozlagam
https://knowledge.autodesk.com/support/revit/troubleshooting/caas/sfdcarticles/sfdcarticles/Warning-...
Edit: never mind. @ennujozlagam got to it first
If you want to keep the associated dimensions/tags, uncheck Disjoin.
Box checked:
Box unchecked:
