Wall surface Patterns on Level Below
Good day,
We are currently moving from Autocad to Revit in the engineering environment.
In our floor plans in AutoCad we showed the substructure (walls below) with hatches while our walls above is only a certain line type pattern.
Is there a way in Revit to do the same. At this moment the walls above in the current view is hatched while the walls below are only solid lines.
Can someone maybe post a video on how this can be done?
Regards
Ryno
Karol_Piroska
I think that the ony way to achieve this is changing view from hidden style to wireframe mode and change line pattern for projection lines for walls to hidden style.
Pattycake_Kyle
I believe there is a way to do it using view range and overlay/underlay (if i'm picturing what you need correctly).
Can you post a couple snips of what you are looking for?
www.pattycake.io
Web based & real time .PAT creator. The largest collection of free PAT files! Over 700+ Pat files ready to download
No plugins or add-ins to install, and Revit compliant!
