Wall join problem (different height walls)
Shamai89
Shamai89
Hello everyone,
I'm working on some project where I have walls that continue in same line but they are different height walls, and when I join them in 3d everything looks fine (perfect align and no line).
Also when I make section in front of the wall and "look" on the wall everything is fine (picture 1), but when I make section through wall then I get vertical lines on wall join (picture 2).
I guess this is something a lot of people encountered but seams like I can't find solution, is linework tool only option?
vitorbortoncello
Yes, only Linework:
Alternatively, you can use an in-place wall and extrude it as a whole geometry:
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
jay_colcombe
Removing the lines are easier, an alternative would be to edit the Wall Profile to keep it a single element and no lines appear in sections
Jay Colcombe
Autodesk Certified Instructor
ctm_mka
even easier, grab the end point and drop it right back on top of each other, usually does the trick where joining does not, especially if you split the walls. although given you are not seeing the lines in the first pic, that may not work. also i highly suggest not doing steps with edit profile, wall foundations get messed up.
jay_colcombe
@ctm_mka Dragging does not work as you correctly expected.
I would personally edit the Wall profile before adding a foundation as i know this works, but even editing a Wall Profile with a associated Wall Foundation automatically works too!
Jay Colcombe
