Wall foundations not joining properly
esemple
esemple
I have a step in wall foundations here that are not joining properly. Usually when I drag to create a step like this, the foundations automatically join, but here they are creating a joint. I've tried the join command with no luck. They are the same wall foundation type with the same eccentricity, just different b/wall elevations. There's a picture of what  Revit normally does versus what it's doing now
Ahmed_M_Heteba
make sure the materials are the same and you aleady joined them if you did so try delet the foundation and edith the material to be same "make sure" and then draw it a gain it sometimes work.
if it didn't please share the file
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
