Wall Colour
revit1980
Wall Colour
revit1980
Guys,
 you see the wall colour code RGB 192 192 192 in material Graphic section.However it is different in the 3d view
Please help me  how can i fix this?
Thanks in advance
ennujozlagam
@revit1980 hello, post the part wall here, so we can check. thanks
ennujozlagam
@revit1980 hello, i tried to replicate what you did and it looks fine in my model.have you install latest updates from autodesk? try to untick use hardware accelerations and see if helps. thanks
it could be colour overrides in VG
revit1980
Thank you very much
 I selected PATTERN>color> no overrride. it is ok now
