Wall Below slab not shown in hidden lines
venkatasalamklTGT5N
venkatasalamklTGT5N
Wall Below slab not shown in hidden lines. Can anyone help me with this?
View range is perfect
Structural Plan View
What I need is shown below
Isometric View for better understanding
apjones
What do you mean when you say the view range is perfect?  The Bottom of the view range should be at the top of the slab.  Anything inside the viewable area below that should be in the "beyond" line style.  What are your settings for the "beyond" line style?   Are they solid?
Pete
>Please Accept as Solution and give Kudos as appropriate to further enhance these forums. Thank you!
venkatasalamklTGT5N
The discipline was set to coordination and so there was an issue. I have updated to Structural now. It works fine (I can see the dotted lines)
"beyond" line style is dotted line...
Sorted out now. Thank You!
