Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Void in Hollow core slab
2 REPLIES 2
423 Views, 2 Replies
I create round void from template and using with hollow core thickness 10 cm. but void are not align on center of section as shown, what step did I make?
Thank you.
Tags (2)
2 REPLIES 2
Jason.P
Is there a reason as to why you are not just using the preloaded Hollow core family that comes with Revit.
Jason Peters
BIM Manager
Autodesk Expert Elite Alumni
teodorb
Hi @Anonymous ,
You should check the parameter that controls the position of the voids inside the HCS family (Position from Top parameter). More details can be found here on how to create your family.
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-E7D7E68A-7794-4458-A691-A1798733D2B2
To change the parameter, you need to edit the family, select all voids an change the value of the parameter from 10 cm to 5 cm.
Kind regards,
Bogdan Teodorescu
Product Owner
