Void family doesnt cuts multiple objects?
Message 1 of 13
Im created a family with two plates for wall to wall conx. and recessed 2" from face of wall and used Void Blend Extrusion for recess but when i place the family on walls it cuts only the wall that i picked and other one stays same (as you can see in the first pic). When i use cut command for it, it just disappear. I also added SS for family page. Can anyone help with the situation?
Replies (12)
Message 2 of 13
Sahay_R
Can you share the family?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 13
Of course!
Message 4 of 13
That is because you use a Face based template. Face based family only cuts the host element.  Create it using a non-host family, tick work plane, untick always vertical and it should work.
Message 5 of 13
Sahay_R
Wall-based template won't work either - it will only cut the hosting wall.
Rina Sahay
Message 6 of 13
Im created new family from "Generic Model" template as you said. Drawn 2 plates and recessed 2" with void blend but when i place it on walls its not even cut anything.(see pics) What am i missing? (family file uploaded)
Message 7 of 13
@Anonymous
You can still keep the face base family.  But don't cut the host solid with the void in the family, when you place it on a wall, use Cut Geometry twice to cut both walls.
Message 8 of 13
Ok i understand the method but when i try it gives me this error.(see pic) Walls are not referenced with anywhere (they are all in-place objects) i couldnt understand why im having this error. I also uploaded the project.1.jpg
Message 9 of 13
Did you see my screencast? I believe I ignored the error warning and carried on with cutting command. It works. I can take a look at your file later.
Message 10 of 13
Yes i saw your screencast and tried on two basic walls and it worked like charm. You ignored error about instance but this error says "cannot be ignored" as you can see on pic. I will be very grateful if you take a look at the project.
Message 11 of 13
I only see two instances of the family so I fixed them using the same procedure I have described.  Remember, DO NOT cut the solid in the family with the void.  Edit the family in the attached file and you will see what I mean.
Message 12 of 13
Ok i got it. This method will be very helpful for my other conx. details too. Thank you very much for your awesome help Toan!
Message 13 of 13
gccdesign
Did the trick for me.
As he says, don't cut the host within the family editor.
Do check "Cut with Voids When Loaded".
GChapp
