Void blend issue
Void blend issue
geteway2digitalindia
Void blend issue
After successfully applying void blend to all the profiles, I am stuck with this one profile. I tried By skething boundaries, by pick line boundaries, & also by sketching additional detail line, but nothing is working.
Pls suggest.........
jay_colcombe
Its not a pretty model and looks like there are lots of other voids with strange spikes etc. but I simply copied the void to the right and then edited using ALIGN to the the grey lines for the top and bottom Void Blend Faces
Jay Colcombe
Autodesk Certified Instructor
Please throw some more light on the operations of "Copy void to the right>>Create void blend>>Align to the original location"
As I understand a void-blend can be hosted on a blend only.
In my case the blend is a continuous structure (in yellow) of 200mm thickness having many void-blends of 200mm depth successfully created. The lines indicating the void boundary are derived from the autocad drawing as an underlay.
In this setup please elaborate :
1. What did you copy to the right ? - the full blend or a segment of the blend that will host the void-blend
2. How did you get the void boundaries on the copied blend ?
3. How did you align back the void-blend created at a different location to its required location by using the Align command.
A step-by-step video will be appreciated....
