Visualize Loads on a Plan View
pipapongo0909
pipapongo0909
Hi Forum,
I have a project where the engineers want to visualize the loads applied to floors and foundations.
We have no connection between our analysis software and Revit so we do not even have loads defined.
What do you think is the quickest solution?
i just need to create regions and put some values [kN/m²] to an assigned paramter.
Any ideas?
Thanks in advance
Jeff Wurth
BIM Manager | Dipl Ing. Bauingenieur
LinkedIn
ennujozlagam
@pipapongo0909 hello, you can try this edit your room tag > duplicate > add parameter for your [kN/m²] but need to key-in manually once loaded into your file. thanks
Create Area Plan and Areas with different loads. Then use Area Color schemes to show them in different colors.
